any wany to protect the paint when using tailgate chains?
Picked up a decent used tailgate, and i really like the look of the original chains, but is there a way to protect the paint around the stock latch area? I know the chain covers help the chains from slapping around, but what about where it loops around the tailgate? What have you guys done??
On the other hand, there are some nice inside latches around (homemade and store bought) but i would still need a clean and relatively cheap way to hold the tailgate up when its open.
Don't quite understand the area you are describing. Bicycle inner tubes work well as chain covers. Other than the chain, my 55 latch doesn't contact the paint.
Fred
They do make some custom inside latches that are spring loaded and fit in the upper rail of the tailgate. They are too pricey for my taste though running about $100 for a pair of them.
I recently rebuilt the tailgate on my 49 and fabricated my own spring pin latches to hold the tailgate closed (see my gallery "poor boy tailgate"
You could apply a coating to the hook. I don't know what it is called but they used to market a can of stuff that you could dip your tools into, screwdrivers, pliers, etc andit would make a thin rubberized coating on the tool. If you dipped the hook portion of your chains in that stuff and then used an old inner tube over your chains it should protect your paint pretty well.
You could use woven steel cable that has hook and eye swaged in and then plastic coat the cable with that dippable tool handle stuff. The swages, properly applied hold an unseemly amount of weight. The woven cable is stiff enough too so it does slap around like chain. I think that is wht I'll do for my '53.
I am very careful and I do use my truck to haul stuff, yard waste, mulch, bikes, etc. I try to open the tailgate as little as often. Also I use touch up paint.
abe
PS: the rubberized idea sounds good but then you lose your truck color!
Thanks for the advice. i have heard of that coating, maybe that would work well.
I dont have everything together so i cant take a picture, but i dug something up to show what im talking about. Where the hook loops thru the tailgate ear. I guess i could always put a rubber grommet in the ear as well.
[IMG][/IMG]
PS - yes that bed and tailgate in this pic are chrome. a pretty rare Mercury tailgate too. Took this picture at a car show. different strokes for different folks i guess.....
I see what you mean. The hooks on my 55 don't flop around and never touch the paint except inside the ear hole. There is little that can be done to stop that unless the hook is coated.
Fred
I've used the coating stuff on my hooks and it works pretty good. Just don't get too carried away as a heavy buildup might not allow the hook to go thru the hole. One dip and mine's a tight fit!
Isn't there a sleeve you can put over your "Tail Gate Chains" to prevent them from scratching the paint?? I've seen some "see-through" and some the color of the truck and some "black".
3-M makes a clear sheet "Invisable Bra" that could be cut and placed to protect the painted area from the chain. My chain on the ole 49'er has the rubber cover, but it still rubs and mars the paint.
Here's some for $59.95 for plain(?), and $79.95 for stainless...bottom right...
