Bronco II Ford Bronco II
Heater switch:
Old Dec 13, 2006 | 12:47 PM
blockheadbob's Avatar
blockheadbob
Heater switch:
I have a 85 bronco II and the heater switch just quit working. Prior to it quitting it would work for a while and then quit. I have the switch out and I checked the voltage on the 5 wires to the switch and I am getting 3.8 volts on 4 out of 5 wires. Any ideas.
Thanks,
Bob
Old Dec 13, 2006 | 01:54 PM
youngfordguy's Avatar
youngfordguy
ont the heater box under the hood there is a resistor, it controls the fan speed when u turn the swithch. if that resistor is screwed then your heater motor wont work. cheack the resistance of that restor. i dont know the specs for it but it might say in the manual. if not i might be able to find it here in the back room at work.
Old Dec 13, 2006 | 08:10 PM
Dealford's Avatar
Dealford
Also...
With the resistor being subject to the outdoor elements, the contacts corrode and sometimes cause the connectors in the plug to heat up, melt through the plug body and short each other out. Check the resistor and plug before you throw any other parts at it.
AL.
