7.3 stalled,wont start
Old Dec 13, 2006 | 11:49 AM
wsm's Avatar
wsm
Angry 7.3 stalled,wont start
I was on my way to work this morning and my engine died when I was doing about 70mph.Now it will not start, The engine turns over fine but the wait to start light does not come on. Got towed home and took the other car to work. Any ideas on where to start troubleshooting would be appreciated. I am new to diesels but have good mechanical and decent electrical skills.
1989 F250 4X4 7.3 IDI NA E40D
Thanks
Old Dec 13, 2006 | 11:56 AM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
If your 89 is wired like my 93 - check to see if the fuel shutoff wire came off or has no power. It is the wire going to the injection pump. If no power then we will go from there.
Old Dec 13, 2006 | 12:00 PM
wsm's Avatar
wsm
Thanks, I will check that first when I get home. Will that cause the wait to start light not to come on? What else could cause that?
Old Dec 13, 2006 | 12:02 PM
bigredtruckmi
Veteran: Navy
Also wonderng if the key switch has gone bad. This would cause the same thing and not feed power to the GP relay/controler. I had this problem a couple of years ago.
Old Dec 13, 2006 | 12:14 PM
wsm's Avatar
wsm
That is very possible. The switch had gone bad some time in the past because the previous owner had a push button start installed. To start the truck I would turn the key all the way, wait for the "wait to start" light to go out and the push the button to start the engine. If the switch has gotten worse that could be the problem. I didn't think of that because all of the other dash lights come on when I turn the switch. If the switch is bad any idea where I can get one? Do I have to replace the whole column? Thanks
Old Dec 13, 2006 | 12:34 PM
bigredtruckmi
Veteran: Navy
Local auto parts store should have one with directions on replacement. Not sure if any special tools required. Ask at auto parts store they might lend/rent it to you. If needed.
Old Dec 13, 2006 | 01:29 PM
dieselbogging's Avatar
dieselbogging
Its not all that hard. You might want to pull the steering column right out to do it easily. I had to do my blinker switch which involved pulling the ignition apart and the switch as well. No special tools required.
Old Dec 13, 2006 | 02:33 PM
wsm's Avatar
wsm
thanks for all the info guys
bigtexan99
18
Apr 12, 2013 02:02 PM
oct7brian
Jan 14, 2012 11:47 PM
bigblock501
15
Dec 2, 2011 06:37 AM
jeff299
Nov 5, 2011 07:40 AM
mgerdes
Apr 6, 2006 06:30 AM
