Mileage, ? Figuring out 77
Old Dec 13, 2006 | 10:09 AM
Pickupmanx2's Avatar
Pickupmanx2
Ok, my 77 F-150 4x, NP435, 9" w/3.50, I originally had 31's on it, from what I can tell, factory tires were about 31's. I went with 255/85/16's which measure out to a 33" tire (tire calc says 32.5, tape measure says 33), @ 2000 RPM speedo says 50, about 2200rpm = 55
So I used one of the calculators, I think it was off about 5mph, so when I figure the mileage.... If I went 300 miles, would I add 5 miles for every 50 driven, so I would actually have gone 330 miles? and use that for my math?!
Old Dec 14, 2006 | 09:07 AM
Pickupmanx2
Surely someone has some info on this?!!
Old Dec 14, 2006 | 09:23 AM
79f3504x4's Avatar
79f3504x4
Sorry I am not good enough w/math to help you. After putting taller tires on mine, the mileage came out to about 7mpg. I decided I no longer wanted to know. I just put gas in it. You have a granny gear, big tires & an M motor, you prolly don't want to know either. If you are worried about distance from here to there, pick up a cheap GPS. Brian
Old Dec 14, 2006 | 09:48 AM
beartracks's Avatar
beartracks
To check your speedo run between mile markers on the highway at 60. You should get one mile on the odometer and 60 secs elapse time.
Old Dec 14, 2006 | 09:56 AM
garypettengill's Avatar
garypettengill
Origional factory tires on your '77 were L78-15's, about 29" tall. Comparable tire today is a 235/75R-15. Your math sounds about right, however you're not going to like the answer. These trucks don't get good milage in their origional configuration. With your 33's you will get about 8 or 9 mpg and that's about it. I know it looks funky but for better milage you need to go with the stokc size tire. I am aware that by increasing your tire diameter you effectively lower the number of your gear ratio but the cost in energy to turn the bigger tires is higher then the gain.
Old Dec 14, 2006 | 03:21 PM
Pickupmanx2
Thanks Guys, when I was figuring it, it came out to about 9.5 - 10, so I am guessing I am close... I think at some point in time I will be building another 300 I6 and put that in. I get 14-16 out of the one in my 66. Or I might stroke it to a 400, it is already punched .040. And the good thing is that it is a NON_Catalyst, no air pump or cat converter. I didn't realize the stock tires were so small!! I might regear then
Old Dec 14, 2006 | 04:05 PM
Torque1st's Avatar
Torque1st
Posting Legend
Check the Read First: FAQ thread at the top of the 73-9 forum for speedometer calibration info.
Old Dec 14, 2006 | 10:50 PM
Mil1ion's Avatar
Mil1ion
A tire with a larger diameter will a greater diatance in revolution than a lessor diameter tire .
so a 29 " tall tire will turn more revolutions in a set distance than a 33" tall tire.
So given that info and the gearing being the same..a taller tire will register a lower actual distance than a shorter tire.
If the 33" tire measured a distance of 2 miles...the shorter tire (29") will register a distance of (for example only) 2.5 miles but the tires actually went the same actual distance.
This is where the calibration figures come in so they will both read the same distance with alterations.
Therefore to answer your question.
With 31" tires you actually registered less distance than the 29" tires.
The shorter tire makes the axles and transmission turn faster and increase mileage indication.
The fuel mileage would read better for the taller tire than the shorter one...... therefore in your case... you decreased the distance travelled and decreased the mileage to fuel calculation making it appear worse than it actually was.
Old Dec 14, 2006 | 11:02 PM
Torque1st's Avatar
Torque1st
Posting Legend
There are a ton of automotive calculators here:
https://www.ford-trucks.com/calculators/index.php
Old Dec 15, 2006 | 10:41 AM
Pickupmanx2
Se were they 29" tires from the factory? So I can do the calculations correctly
Old Dec 15, 2006 | 11:05 AM
sgtrwg's Avatar
sgtrwg
Take a look at this web page http://www.offroaders.com/info/tech-...ng/mph-rpm.htm
It gives formulas to figure out correct speed based on tire size, rearend ration etc.
Old Dec 15, 2006 | 02:08 PM
Mil1ion's Avatar
Mil1ion
The original tires I think were around that.
Here's a chart.
