Is there a difference between the headliner used in a Custom Cab, and that used in a standard cab?
I got a great used headliner from a guy complete with clips and screws, but it came out of a standard-cab, while my truck is CC. I wouldn't ask, because it seems to fit just fine, but I think there will be an issue with putting the chrome trim back on; I don't see how it will fit with the headliner in place. I haven't dug out the trim pieces to do a fit check yet, just wondering if I should be AWARE of a difference before I jam something together.
I don't see a problem...the roofs are identical...there may have been two different styles of headliners originally..with and without the holes. When I replaced mine (bought the truck back and the original was missing)...it was with the perforated type. The corner pieces came flat and had to be bent into shape. Some trimming was required.
This was back in the early 1980's when the headliners sections were still available from Ford.
