Limited slip 9"
Old Dec 15, 2006 | 06:11 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The 9 inch clutch type limited slip was introduced in 1959. Besides the usual rear end tag..there is a separate tag with just the letter L on it. Yes, I know chances are slim that tag might still be on a rear end...but I thought I might as well pass the info along regardless.
Old Dec 15, 2006 | 01:09 PM
monsterbaby's Avatar
monsterbaby
Originally Posted by RTM
I have never seen nor heard of a 3.54 9 inch ratio. I guees that doesn't mean there isn't one but I have been around some older guys that have taught me the things I know so I kind of rely on them and the net for my info.
Not sure if it was a factory ratio or not (I am pretty sure it was but not 100%) but you can get almost any ratio you want in a ford 9" gear click HERE for richmonds catalog it shows a 3.50 and a 3.55 ratios, and I know I have seen 3.54 just can't remember which company it was.
Old Dec 15, 2006 | 02:57 PM
RTM's Avatar
RTM
First time I've ever seen a 3.55 for a 9 inch.
Old Dec 15, 2006 | 03:52 PM
rebocardo's Avatar
rebocardo
> There is no such thing as a 3.54 for a 9 inch axle.
I should have said 3.55, which is what it could have come with from the factory with the 3.54 Dana 44 front axle. Which I have owned in old 4x4 Ford trucks.
Old Dec 15, 2006 | 03:56 PM
andym's Avatar
andym
Ford never put a set of 3.55 gears in a truck 9" axle. You can get them aftermarket, but not from the factory.
Old Dec 16, 2006 | 07:13 PM
rearendman's Avatar
rearendman
Ford used a 3.555555, which they rounded up to the 3.56 in the late 50's;
You will find these typically in WAR, WAA, or WAB cases during the days
when the tags were simply numbers. The tag would only read "356".
Old Dec 21, 2006 | 12:26 AM
Redbob's Avatar
Redbob
Originally Posted by rebocardo
Correct me if I am wrong, the 3.50 9" came in the 80s (ex: full sized broncos). A 1979 truck would have the 3.54.
You're wrong - you've got it exactly backwards: the 3.54 came in the '80s, and then only on those silly little 8.8s.
And any of the trucks he listed in his signature line would have come with 31-spline axles.
Basically, E-100/150 vans came with 28-spline axles, pickups and all 4x4s (full-size at least) had 31-splines.
Old Dec 21, 2006 | 02:50 AM
Netfly's Avatar
Netfly
I still have an extra third member from my 85 Bronco 9" LS. Its 31 spline but I'm confused about the ratio. In the 80's I thought they called it a 3.55, but now I see replacements are 3.50 ...Guess it's a 3.50
http://broncograveyard.com/bronco/c-...rd_members.htm
Old Dec 21, 2006 | 04:41 AM
LEVEL10's Avatar
LEVEL10
randy's ring and pinion, has some very good rear axle parts and great prices. he could also help get you the correct information.
Old Dec 21, 2006 | 09:06 AM
andym's Avatar
andym
3.55 and 3.50 aren't names - they're mathematical ratios between the ring and pinion.
If your Bronco has a 9", then it most likely has 3.50 gears - in the rear at least. If it has an 8.8" axle, then it probably has 3.55 gears. Front axle ratios are different, obviously. They are rarely an exact match from the factory.
Old Dec 21, 2006 | 09:29 AM
Redbob's Avatar
Redbob
And you can always tell the ratio with a little math:
if it's out of the truck, divide the number of teeth on the pinion gear into the number of teeth on the ring gear.
If it's in the truck, jack up one wheel, put a visible mark on the driveshaft, and with the trans (or transfer case) in neutral, rotate the one wheel two complete revolutions.
The number of times the driveshaft turns is your ratio.
whisler
Ford Truck Parts for Sale
Nov 15, 2015 04:14 PM
ramair428cjxr7
1997 - 2003 F150
Mar 16, 2015 05:10 PM
sanders46
Jun 18, 2014 07:44 PM
Vaccuum
Sep 28, 2001 05:28 PM
Beatpulp
1978 - 1996 Big Bronco
Sep 30, 2000 03:52 PM
