I have looked through all the little things that could have happened including fuses, relays and the fuel cutoff. Lets start with this my truck is a 93 ford flareside 5.0 4 spd manual, middle of the year i took my truck off the road to spray it and clean up loose ends and such. this past saturday my truck ran fine besides a dull battery. Sunday i rewired my audio system and installed some lights on my reciever hitch because the regular reverse lights sit 5 ft off the ground and dont help. after reworking these few things i find my truck not starting. it cranks over and over, today thinking it was just a cut off i bought a optima expecting it to start right up after resetting the switch so i could register it thursday.. and nothing still. the fuel pump is not turning on dont know where to go now
i also tested for power at the pump with the key on but there was no power. am i wrong in thinking i maybe i fried my ecm or something. i plan on testing the ecm power feed first but thats the way im leading
dont worry about this some jerk wanted to put the switch for his new reverse lights next to his headlights so he removed the harness attached to the blank. that harness is for a tank switch if you need it, it has jumpers, i didnt replace the jumpers correctly
