Knocking?
Old Dec 12, 2006 | 04:51 PM
koldstart's Avatar
koldstart
Knocking?
99 Ford Explorer
86K Manual 5spd AWD
I was running low on gas so I swung by a cheveron and filled up on regular 87 octane gas. Before I pumped the gas, I added a fuel additive that was supposed to clean deposits on valves, injectors.. etc. After that, I drove it home and did an oil change, using Motocraft 5W-30, manufactures spec. with a basic FRAM oil filter
Now I have a knock at idle.
Is 5W-30 Oil to thin for an engine that has 86K on it? Should I drain it and add 10W-30 or something thicker?
The Knock is prrrrrety ugly sounding.
Old Dec 12, 2006 | 08:23 PM
JerrySimm's Avatar
JerrySimm
86K is not much milage. What engine do you have. I have read about the 4.0 SOHC having a knocking issue with the timing chain cassettes around your year model. You might try searching for the SOHC and timing if the search feature is working. Seems like I remember reading about a recall on some models.
Old Dec 13, 2006 | 01:02 AM
koldstart's Avatar
koldstart
Yeah, I know it's what worries me. I actually have the OHV which from what I have read are the better choice out of the two. The noise sounds deep, hear it best with ear in the driver-side wheel-well. Tommrow im going to try to run some 10w-30 and use a different filter, Mobil-1 instead of Fram; seems like there isn't a whole lot of fram fans out there.
Old Dec 13, 2006 | 09:11 AM
marragtop's Avatar
marragtop
If the knocking started right after the oil change, change the filter. Also, pull the oil cap off and make sure it's pumping oil to the valve train.
Old Dec 13, 2006 | 05:18 PM
koldstart's Avatar
koldstart
I flushed out what was inside of pan (5W-30) and replaced it with Mobil 1 10w-40 also replaced the FRAM with a Mobil 1 filter. It minimized the sound, but it is undeniable - it's still there.
Sounds like it 'wants-to-be-a-diesil'
Pull the cap running? or after and look inside? what do you mean by pulling the cap?
Should I try lucus?
Old Dec 13, 2006 | 08:23 PM
JerrySimm's Avatar
JerrySimm
Are you hearing something like a rod knock or a spark knock? I was assuming you were hearing it at idle and it was like a rod know from your earlier posts.
Old Dec 14, 2006 | 12:06 AM
koldstart's Avatar
koldstart
Well, I honestly can't feel confident saying I can determine a spark knock from a rod knock, but yes, at idle is the only time I can hear it, weither it be the normal engine sound and road noise muffling it? Im not sure.
Is there a way to deterimine? I had bought a new set of plugs; havn't had the pleasure of starting that adventure yet.
Timing?
Old Dec 14, 2006 | 08:01 PM
JerrySimm's Avatar
JerrySimm
If it's at idle, it's not likely to be spark knock. You'll usually note spark knock when the motor is under a load. Timing would cause spark knock, but the 4.0L is distributerless and the timing is all electronic. It is a ticking noise or a knocking noise? Ticking is not that uncommon.
Old Dec 14, 2006 | 08:16 PM
koldstart's Avatar
koldstart
I'd call it more of a knock, I understand that it's tough and frustrating to diagnose over the internet, but I'm really not sure. It sounds like a diesil, that rattling knock-y sound. I have that Lucus stuff, supposed to reduce friction and other magical goodies that regular Oil can't. Torn trying it, or something else. But I really want to get it figured.
If it is a knock; I hope it's not knocking on heavens door. haha.
Old Dec 14, 2006 | 08:36 PM
koldstart's Avatar
koldstart
Jerry, If i sent you a recording of the noise, would you bother to listen? or is there a way to post a sound on this page?
Old Dec 14, 2006 | 08:46 PM
JerrySimm's Avatar
JerrySimm
Yeah, i'll have a listen. Try to keep the file reasonable, I'm stuck with dial up
Old Dec 14, 2006 | 08:52 PM
koldstart's Avatar
koldstart
Says I can't send you a message, you requested no emails.
It's ok, the sound quality is terrible, it was taken via cell phone.
Any other thoughts? Lucus oil stabilizer? --anything?
Old Dec 14, 2006 | 09:04 PM
JerrySimm's Avatar
JerrySimm
I'm not a big fan of Lucas. If it's not making the noise at higher RPM's or under load, I don't know that I would be overly concerned. Wonder if you could post it up like a picture in your gallery?
Old Dec 14, 2006 | 09:12 PM
koldstart's Avatar
koldstart
Doesn't look like that is going to be an option.
It sounds just so terrible when its idling tho. It idles hot around 900 too.
after I pulled the IAC it sounded like marbles where dropped down in the block
Old Dec 14, 2006 | 09:23 PM
JerrySimm's Avatar
JerrySimm
That kinda sounds like a vacuum leak. What do you mean by "pulled the IAC"? Unplugging the wires or opening the intake?
