Sub under rear single seat
I have an 04 Screw -- Anyone know of a good setup for putting a single 10 or 12 under the small part of the bench seat? And then where to put the amp? The reason I need it under the small part is, this keeps it to wehre I can still lift up the long part and throw my dog in there which is good... anyone have any ideaS?
if you go to www.crutchfield.com there should be a few different setups. the only 10 or 12 i can think of would be a Pioneer TS shallow mount sub. pioneer makes a box for it that holds a 10 and is supposed to fit underneath seats and the box will be somewhere in crutchfield.
I looked on cruthfield to try and find a box that would go under the seat and couldnt find one -- plenty of subs to choose from though. I want a box that will go under the rear seat, but JUST the small section...
Visit a specialist car audio retailer and have them build you an enclosure - you will most likely be limited to an 8" woofer in a sealed enclosure for that amount of space.
Contact me at Mark@SuperCrewsound.com We can build that for you fairly easy, It is just the box portion of our dual box that fit on that side. Up to a 10" if it runs in a smalll air space. Like the pioneer shallow mounts.
