1989 f250 5.8 runs then dies, then runs...then dies...on and on
Old Dec 28, 2006 | 02:36 PM
subford's Avatar
subford
From what you say it is foregone conclusion that it will not pass the time/volume test.
The hi pressure should run steady and it will not slow down or stop when the head rises or it loses prime as fuel will be pumped right back into the tanks as it runs.
I would put a test light on the power wire as it goes into the pump as it runs and see if it flutters or has a steady light when the pump messes up.
Old Jan 1, 2007 | 06:27 AM
1989f250lariat's Avatar
1989f250lariat
Took the bed off
Took the bed off, connector on the rear lift pump was heavily corroded, put power to both lift pumps, neither work - verifed good power to pumps but they're dead -
Old Jan 6, 2007 | 10:47 AM
1989f250lariat
Problem solved
turned out that BOTH lift pumps were bad. Seems like if you let truck sit for a while, dual function resevoir would fill (siphon?) with gas and allow truck to start and run for a short time, but after about a minute, high press frame rail pump would be starved out. By doing the time / volume test at the dual function resevoir, then verifying good 12v and ground at the pump, pumps did not function. Bought // installed new pumps, runs like a champ. Too bad pumps are 160.00 a pop....
Thanks for all the input and advice from everyone while I was diagnosing this -
Old Feb 24, 2007 | 08:17 AM
koolkat32's Avatar
koolkat32
Same problem here
I had the same problem with my ford....there is a M.A.P. sensor located on the upper passenger side firewall next to the AC housing unit. Dont run out and buy one before testing it first...they are 60 bucks. All you need to do to test it is with the engine running unplug the darn thing....the engine will idle a little faster and it should stop the surging. Replace if this is the case....
Old Oct 31, 2022 | 09:14 PM
Kar Kar's Avatar
Kar Kar
2nd Gear
[QUOTE=subford;4254803]Here are some images and diagrams to look at if you have not already seen them.
Fuel System Diagrams for the 87-89 F series:
Electrical:
http://i54.photobucket.com/albums/g9...-89FSeries.gif
Mechanical
http://i54.photobucket.com/albums/g9...Fuelsystem.gif
Selector Valve 1:
http://i54.photobucket.com/albums/g9...Fuel/dfres.gif
Selector Valve 2:
http://i54.photobucket.com/albums/g9...l/FuelRes1.gif
Selector Valve 3:
http://i54.photobucket.com/albums/g9...l/FUELRES2.gif
Selector Valve 4:
http://i54.photobucket.com/albums/g9...ectorvalve.jpg
In Tank Fuel Pump:
http://i54.photobucket.com/albums/g9...9FuelPump2.jpg
High Pressure Fuel Pump + Filter:
http://i54.photobucket.com/albums/g9...mpFilter88.jpg
Fuel Pressure Regulator:
http://i54.photobucket.com/albums/g9...Fuel/fpr02.gif
Fuel Manifold:
http://i54.photobucket.com/albums/g9...elmanifold.jpg
Fuel Pumps test ground at the Test Connector:
http://i54.photobucket.com/albums/g9...taLinkConn.jpg
Inertia switch location 87-89:
http://i54.photobucket.com/albums/g9...SwLocation.gif
countrysidemetalwork
Jul 16, 2014 06:36 PM
bluethundersowner
Nov 16, 2013 11:24 AM
cummins2005
Sep 9, 2013 11:59 AM
cceretti
Jul 1, 2008 12:02 PM
jlev89
Sep 22, 2006 09:44 PM
