Sponsored by: Real Truck
ABS light
Old Dec 11, 2006 | 09:34 PM
Bone683's Avatar
Bone683
ABS light
I have tried searching for it but didn't find anything and i know i can't be the only one with this problem.
My ABS light comes one while driving but goes off, coming on, goes off and so on
I was told by a Ford tech to change out the VSS on the rear diff so that was done and still nothing
Any ideas on what this could be ?
the truck is an F350 4x4 v10
Old Dec 11, 2006 | 09:57 PM
ReAX's Avatar
ReAX
ABS module, cluster or wiring between. You may need have the GEM scanned to see if it is communicating with ABS system.
Old Dec 11, 2006 | 10:35 PM
mlb4966's Avatar
mlb4966
COMPUTER. Here is a quote from a post I did a few weeks ago.
Subject: 2006 F350 Lariet ABS Light
To Whom It May Concern:
This is a log of the ABS Light problem that I have been having for the past 8 months since purchase of above truck.
1. May 2006 (4368 miles) – While towing a empty car hauler the ABS light came on. The cruise control was activated then suddenly stopped. I reset the cruise control and it stopped aging along with the ABS light kicking on. The light stay on for approximately another 130 miles. The following day the ABS Light had reset. I stopped at Cal Worthington Ford but was told that they could not look at my truck unless the light was on.
2. June 2006 ( 5200 miles) – Same situation as above except it occurred while leaving Anchorage and heading back to Valdez. Stayed on the entire 305 miles.
3. July 2006 ( 6500 miles) – Once again the same situation as above. Occurred while heading back to Valdez. This time I did observe that right before the ABS light kicked on the Spedo dropped to zero than jumped back up to highway speed as the ABS Light kicked on.
4. August 2006 (Started at 7800 miles) – This time I was towing my 36’ 5ther on a 2000 mile trip through the Yukon. About 150 miles from Valdez it kicked on and stayed on the entire trip. This also occurred with a side trip to Skagway without the trailer. The only exception is that I was able to utilize the Cruise Control on this side trip.
5. Oct 2006 (10500 miles) – Same story with 5ther but to Fairbanks this time. Seekings Ford had no techs available when I stopped in.
6. Nov 2006 (11500 thru 14500 miles) – Three trips to Anchorage. Two with trailer and one without. In all cases same issue with ABS. I did stop in Cal Worthington the morning of the 3rd trip and was told this time that they did not necessary need the ABS Light on to look at the truck. Talked with the Service Rep about speed sensors in the wheels and he informed me that it was more than likely the Speed Sensor computer. Might not have that exactly right.
7. Nov 2006 (14500 Mile) – Wife driving to school to pick up kids. She stated the spedo just quite working for 10 minutes then magically began working again. Of course when it started the ABS Light kicked on.
So as you can see it initially started with towing trailer but has progressed to doing it with or without a trailer attached. Will try to established an appointment in Dec to have this looked at.
Revised 21 Nov 06
edsheridan
Aug 25, 2014 02:39 PM
kbjafd63
Oct 5, 2012 01:42 PM
meb9796
Dec 22, 2009 02:07 PM
94Rangerbeater
1983 - 2012 Ranger & B-Series
Nov 28, 2005 02:30 AM
jayhawkfan
Feb 19, 2004 03:29 PM
