high idle
Old Dec 11, 2006 | 08:31 PM
ton-550's Avatar
ton-550
Question high idle
Drove the truck 300 miles,stoped and let it idle for like 20 minutes.During that time the idle would go way up as if it were a cold moring.Hit the brake it would back down.Never noticed this before.It does do this on cold mornings so I hit the brake and it goes back down.2001,7.3. Thanks
Old Dec 11, 2006 | 08:38 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Must have been really cold. Any time certain temperature conditions are met and the truck is parked it will kick up the idle.
Old Dec 11, 2006 | 08:43 PM
ton-550's Avatar
ton-550
Thanks,it was cold and very windy.Had the truck for awhile and never noticed that before.
Old Dec 11, 2006 | 08:51 PM
cookie88's Avatar
cookie88
FTE Emeritus
It won't happen too often. Last time mine did it, it was about 3 degrees and the nose was pointed into a 30 mph wind at a truck stop. Really cold.
Old Dec 11, 2006 | 08:52 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Yes, it's normal like Scott said. Did you catch what RPM the high idle was at?
