Rear Axle Question
Old Dec 28, 2001 | 03:36 PM
fyrtrks's Avatar
fyrtrks
Rear Axle Question
I would like to put a 351 and a C6 in my 53 will my stock axle handle the HP and torque or should i upgrade to something newer?
Old Dec 28, 2001 | 04:42 PM
copeina's Avatar
copeina
Rear Axle Question
Your rear axle will handle the new stresses without a problem (unless there was a problem there to begin with...)
You may want to consider a different gear set later on, but for now, do the swap without fear.
Good luck,
/Kris
Old Dec 28, 2001 | 05:09 PM
truckzilla's Avatar
truckzilla
Post Rear Axle Question
The axle should be tough enough but you may not be happy with the top end altho even that will be better than what you now have - especially if its a 6.
Old Dec 28, 2001 | 08:04 PM
fyrtrks's Avatar
fyrtrks
Rear Axle Question
[updated:LAST EDITED ON 28-Dec-01 AT 09:06 PM (EST)]Yes it is a6 215 or the smallest one it *****$ and gets fairly well I can do 55 to 60 in it but it is obvously wound out.
Thanks
Dan Jenkins
Old Dec 29, 2001 | 09:54 AM
62stepside's Avatar
62stepside
Rear Axle Question
The '53 rear end should hold up, but swaping it for a 9" is simple. I got the rear end out of a '67 f100 and it is a direct bolt in. The hardest part is the shock mounts, which are different. (you need the u-bolts and spring pads as well) I had the guys at the scrap yard cut the shock mounts off the frame of the '67 and I'm just gonna bolt them on to the '53 frame. (with grade 5 hardware) Conviently, I have my '62 frame sitting next to it so I have the correct reference points... :-) I'm not sure if I'm going to have to shim the springs to get the correct pinion angle yet, as I don't even have a motor or tranny in yet. Though I have a 429/C6 that I'm looking at in an old t-bird...
Tyson
Old Dec 29, 2001 | 10:34 AM
truckzilla's Avatar
truckzilla
Rear Axle Question
Godlover
May 29, 2012 02:39 AM
Powermonger
Sep 29, 2011 06:35 AM
2valvekid
1983 - 2012 Ranger & B-Series
Dec 29, 2005 03:53 PM
mebush
Dec 1, 2005 10:50 PM
liftedwhitef150
1997 - 2003 F150
Jul 26, 2004 09:58 PM
