Sponsored by: Auxito
Paint Valance
Old Dec 10, 2006 | 07:05 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
Paint Valance
Has anyone ever painted there valance... im wanting to match myne to the truck... getting a paint that is close and will stick to the plastic would be pretty hard i guess.... im wanting it to be smooth to like the body.... any help woud be apprciated... thanks
Old Dec 11, 2006 | 10:48 AM
BURNSTOUGHFORD
? any ideas even if you havent done it...
Old Dec 11, 2006 | 11:17 AM
searay220's Avatar
searay220
For what it is worth. The valance comes in either gray or desert tan from the factory or as a replacement part. If you have a tan truck then bingo.
Plastics are notorious for shedding paint. I know bumper covers are plastic so the factory has a way of getting the primer to adhere. My guess is the primer has a reactive chemical that will etch the plastic and cause a molecular bond.
Sure it is out there on the internet somewhere.
Old Dec 11, 2006 | 11:41 AM
naiku's Avatar
naiku
It's possible, I thought there was an article on here about someone doing it to their truck. I tried looking but can't find it now, I think they had a black truck and painted the valance black.
Have a hunt around, it is possible and has been done.
Old Dec 11, 2006 | 12:53 PM
wgotthardt's Avatar
wgotthardt
I've painted several plastic valances (& other parts) over the years. Obviously the first consideration is do you have the spray equipment/proper materials?
Your local body shop supply house will have either factory-pack paint in qt size or be able to mix the paint code. Start with a plastic prep wipe-down, follow with a sprayed adhesion coat (clear etching material), and finish with topcoat(s) mixed with flex-additive.
Old Dec 11, 2006 | 06:21 PM
BURNSTOUGHFORD
Ya i have the equipment available... and i know the paint code since i did the truck myself... im just wanting to find a way to get the paint to stick...and yes flex aditive is a must... lol thanks guys
Old Dec 12, 2006 | 08:27 AM
wgotthardt's Avatar
wgotthardt
Well then the plastic prep and adhesion coat is the key. It's been a (long) while since I've used the stuff, but I believe it was called exactly that: 'Adhesion Coat'. Clear, sticky stuff that sprayed on quite easily straight from the bottle. That's your primer if you will.
Good luck.
Old Dec 12, 2006 | 08:34 AM
BURNSTOUGHFORD
Thanks for the info...I will try that and let you guys know how it works out.
Old Dec 14, 2006 | 03:00 PM
1fast4.6's Avatar
1fast4.6
i went and bought an aftermarked valance for my rig... its smooth.. got it for 140 bucks or something... ill see if i can get some pics of it up
tiltbilt
Mar 3, 2012 08:26 AM
les55f100
1997 - 2003 F150
Jun 26, 2009 05:18 PM
65f100pdx
18
May 3, 2008 04:34 PM
01LongBedF150
Appearance & Dress-Up
Feb 14, 2007 07:38 PM
JamesSandberg
1983 - 2012 Ranger & B-Series
Sep 14, 2005 10:52 PM
