I put a 10 gauge wire from the + side of the battery to the + (top) terminal of the coil and tried to start it. just like before, it started just fine, but died when the switch returned to "run"
What happens is:
The Igntion switch is powered all thr time from the battery .......with the key in start..12v power runs to coil at the same time power goes to the starter solenoid.
once the key moves to RUN..... Power is cut to the solenoid and then resisted power from the switch runs to the coil energizing the ignition system thru the switch RUN position.
as per the illustration I posted above
With power to the coil coming directly from the battery.... by-passing the resistance wire from the switch....the engine should stay running.
My first thought is to try another Ign. switch ......
How many volts are at the coil + terminal with the key in RUN?
It should be more than 8.5v.
I tried the wire from the + (top) of coil to the + post on the battery... no luck. same thing, will start and run just fine but dies as soon as the ignition switch returns to "run"
I'm going to try and hot wire it using the prove out diagram you sent. just bypass the switch and jump the right wires that are supposed to run stuff. stay tuned.
Have you tested the ignition module, magnetic pickup and the power wires (red and white) feeding the module? Testing modules is free at most parts stores.
Hey Dennis, that's the number on the original switch which worked just fine for so long. I would have to pull the new switch to check its number, but it looks identical to the original. The last 6 digits of the ID number written on the inspection sticker looks like C66559. I don't know where the VIN number plate is on this thing. I thought it would be on the dash like most other vehicles, but it's not.
The ignition switch with 9 pins like the prove out shown above is for the switch shown on the right.
This switch was started in use later in the 78 year.
The earlier 78's used the switch on the left which was a carry over from 1977 ....this switch is a 6 pin.
Dennis, I feel like a damn fool. The inspection sticker says it's a '76, but everything else I just looked at to find a VIN number says it's a '78. I'm sure that makes a difference in what we are talking about. The number on the ignition harness is D8UB-14489-AB (or ...88-AB, it's hard to read). There are 11 slots in the fuse box with a 12th that is not being used, not even wired.
This thread is fast! :)
Anyway... I swear Sailor I had the exact same symtoms you are having with my '75 F150 back in about '78. I put a new Blue Streak module in it then and it ain't acted like that since.
I figure I screwed up the original module because I couldn't afford a battery even tho the battery was bad i was jumping it etc and the alernator you know can make some really high voltage when the battery isn't there to "draw" it back.
So what kinda monkey business you done with the electrical lately? ...just before it started acting up? ;)
It acts as if the resistor to reduce the voltage to the coil while running and is bypassed during starter cranking is bad or at least intermittent right? The module is still kinda working just needs more voltage is my guess. Mine was getting full voltage just that it -wanted- more after it went half-bad?
