Header and Cat project issues
Old Dec 10, 2006 | 12:31 AM
grizz3000's Avatar
grizz3000
89 F250 4.6/7.5, reg cab, 4x4, everything is still stock.
Uh oh, what have I done?
I got some Headman Headers (no need to preach about your favorite brand of headers here) and a new high flow single-in/single-out Cat to install.
First Question: Since my very old busted-up Cat has the 4-bolt inlet attachment, how do I attach my new Cat that has a 2.5 inch pipe for the inlet? Cut the inlet of the old Cat off to 'splice' the new one on?
I have a new Cat-back exhaust sitting in the box to install too which expects 2.5" Cat outlet so I should be good there.
Second question: should I, or do I need, new pipes from the headers to the cat?
I'll be taking the exhaust manifolds and pipes off before I do the oil pan and rear seal, but I'd like to have the right plan and 'stuff' in place before demo.
Thanks in advance!
Old Dec 10, 2006 | 10:11 AM
Conanski's Avatar
Conanski
Are your headers shorties? If so you should be able to use the factory Y pipe. You are replacing the whole exhaust it sounds like so don't be affraid to cut where necessary.
