guages installed today
Old Dec 9, 2006 | 09:39 PM
mjtpolice76's Avatar
mjtpolice76
I had boost guage, trans temp guage and pyro guage installe today. I was wondering what the normal operating values, I should be seeing. Full throtle boost goest to 18-20psi trans temp stays at 100F and pyro ranges from 500- 700F driving aound the city. Are these values normal for a stock tune.
Old Dec 9, 2006 | 09:54 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
Sounds normal.
Old Dec 9, 2006 | 10:00 PM
pbr man's Avatar
pbr man
Those numbers look to be normal for stock. I have a 6spd, so I couldn't tell you about the tranny temp. If you really pull hard with a load you might see 22-24psi, and pyro numbers are going to be 600-900 empty. Is your pyrometer pre or post turbo-that will make a difference on the numbers. Since I took the muffler of mine, I have never got over 1100* even pulling 8K, and that is pre turbo and stock.
