rewiring coil
Old Dec 9, 2006 | 07:08 PM
willydean's Avatar
willydean
Question rewiring coil
I have a 1986 f150 302EFI i rewired the green coil wire and the green wire on the ign modual now it won't start ,i checked the coil with a spark checker and no spark ,i checked all the connection again with a omg meter its pegs on all except a this brown rubber thing about 2" long with wire out both sides of it ,t he meter just bearly moves ---------is it bad??
Old Dec 9, 2006 | 08:10 PM
clunker86's Avatar
clunker86
if you have connected the wires back up right and you have no spark, then yes the ign is bad. when replacing it make sure you take the old one with you or look at the bottom where the wires go in and see what color the plasic is around them wires. you need to get the same color when you replace it.
why did you re do the green wire in the first place? i know it goes to the ign and back into the cab for a tac.
Old Dec 9, 2006 | 08:41 PM
willydean's Avatar
willydean
Smile Reply
I had another post and there was a message saying check the green coil wire, the truck was jolting and dying, and i replace everything the coil, ignition module, distrubitor. So someone told me check the green wire of the coil because he was having same problem. So i checked the wiring and it was bad it had bunch of nicks and cuts in it, so thats why i replace the wiring, let me ask you that brown rubbery thing that has wires out of each side of it can i bypass it? i dont know whats its called it. do you know what im describing? i replaced 3 wires the green igintion module wire, the green coil wire, green wire that is coming out of that rubbery thing. they all was all cut up, bad, melted, it about all i can think of thank you
Old Dec 9, 2006 | 08:45 PM
willydean's Avatar
willydean
__________________
Old Dec 9, 2006 | 11:59 PM
Mil1ion's Avatar
Mil1ion
where is this brown rubbery thing located?
do you have a pic to show us ?
It's best to not fool with re-wiring ignition system wiring.
I assume you just replaced the cut-up green scabby wire with another piece of un-cut wire ?
Old Dec 10, 2006 | 05:32 AM
clunker86's Avatar
clunker86
i think i might have told you to check the green wire. yes you can change out the connecters. that would be what you are calling "that brown rubbery thing that has wires out of each side". if so you can use butt connecters or another type of connecter that will allow you to pull them a part if you need to change. but you dont have to you can just run one long wire. make sure you have a good clean connection on your coil. when i had the problem with the truck cutting of then starting i had a lose wire that jumped off the coil for a sec. hope this helps some. let us know how its comes along
Old Dec 11, 2006 | 04:51 AM
willydean's Avatar
willydean
I got a volt meter and my book out and checked the voltage at the ign modual,and the coil i turn on the switch and hold it on the end of the coil wire it shows 12+ voils going through it ,but i put a spark checker on it and no spark ,i have swap out the coil wire not it, i bought a code reader it showed up 21 & 24 code it gives you a dozen reason for them one it said failure in coil 1 primary circuit any body know what this is ???????????????
