Christmas Present
Old Dec 9, 2006 | 07:02 PM
  #31
THE KING's Avatar
THE KING
You think that i could just take that pipe off and slip it out?
Old Dec 9, 2006 | 07:06 PM
  #32
Uzumati's Avatar
Uzumati
Shavings follow gravity, most of them fall in your face, just go slow and there wont be a problem. There is plenty of room for a drill, I used a clamp on model so I didn't have to worry with a tap.
Old Dec 9, 2006 | 07:40 PM
  #33
ponch37300's Avatar
ponch37300
I drilled and tapped and was worried about the shavings also. after i drilled the hole i stuck a magnet in the hole to get most of the shavings out and i also put a shop vac up to it with my hand cuped around the hole. No problems. Plenty of room to do so don't let it scare you, just take your time and follow the instructions and you will be fine.
Old Dec 10, 2006 | 04:31 PM
  #34
THE KING's Avatar
THE KING
What color is the grey interior? Medium Flint? Can i get the interior paint in a can at Napa or Autozone?
