Over the last couple weeks my truck has begun to wander in the lane while driving. Very hard the keep a straight track. With my wife inside and me underneath and the truck running she rocked the wheel and I looked for any loose joints. Everything looked good except the joint where the pitman arm connects to the rest of the steering.....there was joint movement there. I brought it to the dealer and mentioned the pitman arm. They said everything was tight. Truck still wanders and the joint still has movement. Question: Is there suppose to be movement there? Is it suppose to be tight like the tie-rod ends? Or does the dealed have a bunch of dopes working there? Thanks for your help. Rock on.
the joint should be tight mine was doing the same thing and i replaced balljoints and the tie rod at the pitman arm around 54,000 tightend her right up
I had an '87 Ram that must have had well over 4 inches (I think) of play in the steering wheel. When I test drove it around town it was fine, but on the highway is was a moving deathtrap. I sold it two days later. I steer very clear of every Ram that lookes like it. They were notorious for terrible steering problems.
Wellp......brought it back to the dealer with a parts printout of the steering linkage and the pitman joint hilighted. Told them thats all I wanted replaced. That and an alignment and everythig is tight. Tracks nice and straight.
Conclusion: YOU know your truck better than anyone. If something dosen't "feel" right, it probably isn't.....in spite of what the "experts" at the dealer say. Rock on.
