Sponsored by: Auxito
Code 1131
Old Dec 9, 2006 | 10:34 AM
Zoz5's Avatar
Zoz5
Code 1131
I have a 98 Expedition 4x4 with the 5.4 and 107,000.
The CEL came on yesterday morning as I was driving my daughter to school. It was very cold outside and when I started it, there was a strange whine coming from the engine. Almost sounded like the train whistle on a kids railroad set. As I pulled away, the nengine seemed to be laboring a bit, but again, it was below freezing and I did not let it warm up at all. Then the CEL like came on.
Took it to AutoZone this morning and they pulled the code 1131, which they tell me is the O2 sensor.
Last week I had my mechanic replace the right side manifold gasket as it was leaking. A labor intensive and expensive job to say the least. Could my CEL O2 sensor issue be related to the manifold work? Or is this just a coincidence?
Any idea if this requires some sort of simple cleaning or a full replacement of the sensor?
Old Dec 9, 2006 | 01:08 PM
Bluegrass 7's Avatar
Bluegrass 7
This code is the Ox sensor on the drivers side.
Cold temps can elicit all kinds of noises in an older vehichle.
The use of lubes and loosening agents can contaminate Ox sensors especially ones that have age on them already.
Old Dec 10, 2006 | 07:15 AM
Zoz5's Avatar
Zoz5
Thank, BlueGrass. I appreciate the guidance.
Z
Old Dec 10, 2006 | 08:13 AM
projectSHO89's Avatar
projectSHO89
Correction: P1131 is bank 1 which is the PASSENGER side, not the driver's side.
If this is the same side that just had the manifold gasket replaced, then the fault code very well could be related to the recent work. Any exhaust leak upstream of the sensor will introduce fresh air into the exhaust stream and will cause a faulty reading.
Steve
Old Dec 10, 2006 | 08:42 AM
Zoz5's Avatar
Zoz5
Steve
Thanks, Steve. This makes sense then because it was the right (passenger) side gasket that was replaced. How is this fixed? Is there a chance I will need to replace the O2 sensor?
Old Dec 10, 2006 | 11:25 AM
Wilber15's Avatar
Wilber15
Depending on the reason for the code being set, you might not have a bad sensor. You need to know why the code was set. Lean condition? Rich condition? O2 Heater fault? If that gasket is leaking, it could set a lean condition and set the code.
