Dead on the road NEED HELP!
Old Dec 9, 2006 | 12:53 AM
dwiebke's Avatar
dwiebke
2003 f350 6ltr I was traveling south on I 35 tonight when I lost power. Felt like the motor was not getting enough air. The problem came and went for about 150 miles then the motor quit. After shutting down for a few minutes I was able to restart and find a motel. Any suggestions? Injectors?
Old Dec 9, 2006 | 07:42 AM
CanadaGuy's Avatar
CanadaGuy
On a 2003, I'd be looking into the FICM wiring or the ICP sensor before an injector problem. It could be an injector, but normally a leaking injector will not restart.
Old Dec 9, 2006 | 09:24 AM
BowTieHatr's Avatar
BowTieHatr
what kind/grade oil are you using and what is the temp there? whats your mileage on the oil?
Old Dec 9, 2006 | 09:29 AM
ktomasso's Avatar
ktomasso
This happened to me also, It was a recall on the fuel rail wiring harness. It starts shutting down injectors, one at a time until the computer says there are enough good ones to make the truck run. Hope this helps.
Old Dec 9, 2006 | 05:55 PM
dwiebke's Avatar
dwiebke
I changed the fuel filters and got it running. Still feels like I may have a injector down. It's slightly underpowered and sounds different.
Old Dec 9, 2006 | 05:56 PM
dwiebke's Avatar
dwiebke
I have been using amsoil with 8,000 miles since last change.
Old Dec 9, 2006 | 07:23 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Thats a little bit long on the OCI, change the oil and fuel filters and see if there is any change in performance.
KiwiFord
Jan 27, 2010 12:12 AM
79-400-POWER
1978 - 1996 Big Bronco
Oct 17, 2007 07:46 PM
EB II
Bronco II
Jan 22, 2005 03:11 PM
broncobasher
Electrical Systems/Wiring
Nov 20, 2003 01:07 PM
