Sponsored by: Real Truck
Stuck in 4x4 low : (
Old Dec 8, 2006 | 08:05 PM
El Smitro's Avatar
El Smitro
Today I put it in 4x4 low and pulled a fallen tree up to the flat so I could cut it up. Then I drove around the field and picked up large fallen tree limbs. I didn’t do much spinning and probably didn’t go over 5 mph the whole time. When I was finished I turned the **** from 4x4 low to 2wd. Unfortunately the “4x4” and “low” lights stayed on and the truck stayed in 4x4 low… I pulled a few mud clods from around the transmission and checked the fuses; I guess everything looks good. Which fuses are for the 4x4 ****? No clicking or anything going on under the truck. Any other ideas?
Thanks!
Old Dec 8, 2006 | 10:11 PM
captchas's Avatar
captchas
Guest
first thing is make sure you have power down at the motor. if you do the shift motor failed.
Old Dec 9, 2006 | 07:14 AM
FortyFords's Avatar
FortyFords
We assumed that you followed proper procedure to get out of 4low????
read the manual.
stopped on level ground,foot on brake ,in neutral then turn the switch!!!!!
Rich
Old Dec 9, 2006 | 12:26 PM
NoMo's Avatar
NoMo
When you stop and put the tranny in neutral, let off the brakes so the truck can unload the drivetrain. Then reapply the brakes and go through the shift procedure.
If the correct procedure doesn't work, then it's time to break out the electrical diagnostic equipment. Unfortunately, I don't know which fuse you can pull to get out of 4WD. Check your owner's manual and the "diagram" on the fuse box cover.
Old Dec 9, 2006 | 12:56 PM
Fredvon4's Avatar
Fredvon4
no fuse pulling will make the neat little electric motor shift the transfer case back to 2wd high
This is why I always stress using these systems frequently..... to keep then working and to properly break them in.
The ESOF transfer case motor is not very strong. To shift into, or out of, any of the three positions... it must not be loaded with a lot of back pressure or gear bind
If it worked that day to shift into 4x4 Lo the the odds are good the electrical side is working. Like others have said, the right conditions need to be set up to disengage the transfer case
Old Dec 9, 2006 | 02:50 PM
hydro_37's Avatar
hydro_37
If the weather is cold it may take a little longer to unlock the transfer case also. But make sure you are in neutral and back up a little after you turn the ****.
Old Dec 10, 2006 | 03:45 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Thread moved to the SD forum.
Old Dec 10, 2006 | 04:29 PM
Hellrazor1's Avatar
Hellrazor1
Did you try the old "backup and pray" trick yet?
Old Dec 11, 2006 | 05:54 AM
El Smitro's Avatar
El Smitro
OK, I’m and idiot… I have had the truck for years and I know I have had it in low before, it’s just been a while and I forgot the procedure to disengage… I immediately started looking for what was wrong instead of how to do something right. Thank you all very much!
Old Dec 16, 2006 | 05:54 PM
ImConfused666's Avatar
ImConfused666
Don't feel bad. I did exactly the same thing a couple of months ago. Just forgot to put the dang thing in Neutral. I had it in Park. Won't work. I felt Stooopid.
Old Dec 16, 2006 | 06:15 PM
redford's Avatar
redford
Glad it wasn't something serious or costly.
triton54
1997 - 2003 F150
May 23, 2008 10:49 PM
862001
15
Oct 2, 2006 10:24 AM
wpoling
Sep 27, 2006 06:22 AM
Daman858
Feb 17, 2006 04:28 AM
onebadf250
Sep 28, 2005 12:08 AM
