Sponsored by: Auxito
No start
Old Dec 8, 2006 | 10:51 AM
Smoothbore's Avatar
Smoothbore
No start
My '97 150 4x will not start. Initially thought battery was going bad because when turning the ignition to start there would be a few second delay before the engine would turn over. And when it did turn over, the first revolution or two would be really slow, then it would start normally. I replaced battery, and now have replaced starter. I still get the "click" when you go to the start position.
Have cleaned all cable contacts really well (going to do them again), with the exception of the small gauge positive wire that that connects to the tab on the selenoid. (Any good ideas how to clean it?)
Old Dec 8, 2006 | 12:44 PM
Wilber15's Avatar
Wilber15
could be the relay? check for voltage on both sides of the relay when cranking....
