The 50 f-1 truck i am restoring has the vin plate inside the glove box but it is very worn and can not be read. Where else can i find the vin on this model.
Can someone tell me where i can get decode info for the vin.on a 50.
Thanks
Anyone can build a ch*vy.
ONLY THE BEST BUILD FORDS!
50F1 - the vin will appear on the rating plate on the glovebox door, on the data plate on the firewall (passenger side above the solenoid - if like my 48 and it should be) and on the frame rail - some guys say its on the driver's rail, but mine is stamped on the passenger rail up by the front shock mount. It is a faint stamping - use steel wool and something to cut the grease.
It should be like this: *98RC 138425* for an 8 cylinder or
*97HC 138425* for a 6 cylinder.
The vin tells only that it was not 1948 ('50 vin was a continuation of '49 vin number), that it was 6 or 8 cylinder, and 1/2, 3/4, 1T rated, and the unit production number.
