hissing sound
Old Dec 8, 2006 | 01:06 AM
clintl's Avatar
clintl
hissing sound
heres the scoop i had my 7.3 replaced with a used 7.3 the engine is good however when it is cold the engine makes a hissing sound.when i warm up the truck after it has been sitting in the cold the hissing sound is very pronounced and when i drive that hissing sound is there when i accelerate with little power, but as soon as i let off the acelerater the sound stops.when i begin to here the sound upon acceleration if i step on it more it goes away.after about 15 min the sound stops and i have regular power on acceleration.oh and one more thing i dont here the turbo whistle but i do have power any ideas would be greatly appreciated thanks.i have a 2001 f350 superduty and the weather the past couple of weeks has been -30degrees celcius (cold).thank you for your time.
Old Dec 8, 2006 | 02:44 AM
kbeefy's Avatar
kbeefy
check the other thread about 5 posts ago titled 'hissing sound', that may help.
Oh yeah, check under your truck for some really cold snakes....
EDIT:
OK, it's 10 posts down now.
Old Dec 8, 2006 | 06:13 AM
white Buffalo's Avatar
white Buffalo
[QUOTE=kbeefy]
[QUOTE] good one....
clintl,
The sound is normal. It is your EBPV closing to help the engine wam up in cold weather.
Old Dec 8, 2006 | 05:37 PM
clintl's Avatar
clintl
but when i drive i do not here the turbo whirring although i can feel it when i accelerate after it has warmed up and that hissing sound is gone.i looked for snakes under the hood but didnt see any i saw a pigeon 4 cats and a guy asking for spare change so i closed the hood so i think i am ok because i didnt see any snakes.but what about the turbo sound thanks.
Old Dec 8, 2006 | 05:56 PM
white Buffalo
Talking
The EBPV reroutes the exhaust gasses in order to warm up the engine. So until your truck warms up it feels like you just disconnected/lost your turbo. Feels like a dog doesn't it? What temp is it outside?
After she warms up, all is back to normal and the world is good again.
AMiller or one of the other guru's will chime in with the technical data... oopps - you beat me before I was finishing my edit Alan! Your fast....
Old Dec 8, 2006 | 05:59 PM
Uzumati's Avatar
Uzumati
With the EBPV Closed the turbo will make very little boost. Once the Engine oil Temp comes up to 131*F the PCM opens the EBPV and the Turbo can start producing boost again.
Old Dec 8, 2006 | 10:44 PM
clintl's Avatar
clintl
what about the turbo whirring sound i dont seem to hear it i was in my friends truck his is 2 yrs older and i could really hear the turbo whistle.
Old Dec 8, 2006 | 10:47 PM
Tenn01PSD350's Avatar
Tenn01PSD350
What year is your truck and his? He may have the earlier model with what is now known as the wicked wheel and you have a later not wicked wheel model.
Old Dec 8, 2006 | 11:00 PM
clintl's Avatar
clintl
mine is a 2001 super duty his is a 1999 f350 lariat
Old Dec 8, 2006 | 11:23 PM
Tenn01PSD350
There's your answer. He has the earlier turbo in all likelihood. Nothing wrong with your turbo.
Old Dec 9, 2006 | 01:00 AM
kbeefy's Avatar
kbeefy
Well, theres you problem right there!! Every time I found some fellow wanting change under my hood I had a noticeble loss of power! That change is for my pulling power... get lost!! Find your own tow vehicle!!!
All jokes aside, the EBPV should work when it's cold and has low/no exhaust backpressure. Your old motor was probably working as it shoud, and the new one had a clogged ebp tube. It's a common cause for weird EBPV operation. Clean and reinstall, you should be good (hopefully)
Old Dec 9, 2006 | 07:52 AM
white Buffalo
You could change to the earlier style turbo wheel (whicked wheel) if you like.
