Fuel tank sizes
Old Dec 7, 2006 | 08:04 PM
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
Fuel tank sizes
Hello all you Ford truck gurus.
I have a couple of questions regarding the dual fuel tanks I have in my 1976 F-250. I have no owners manual or repair manual for this beast yet, and was wondering if anyone could tell me what the capacities of them are. They both are on the left side of the box, and I am guessing they are factory installed. I noticed the previous owner only filled the rear tank though, never the front.
My second question is, that I thought there would be a switch or lever in the cab somewhere to switch between the two. But I was cleaning out the cab today and looked all over for one, and could not find it.
Old Dec 7, 2006 | 09:01 PM
samickguy15's Avatar
samickguy15
I've seen the factory tank switches next to the heater controls. It may be a gravity feed, where they just equal out or something. Not sure...
Old Dec 7, 2006 | 09:24 PM
plowpusher's Avatar
plowpusher
Basic tanks are rear 19.5 midship about 22 look at your heater controls one side is fan the other should have a fuel tank selector. The actual valve is under the cab on the drivers side floor pan about mid way most times the grounds go bad and the valve quits working. I'm putting together a 79 and putting on factory dual tank setup but I think I will find a manual valve like the older trucks had, to avoid the hassle.
Old Dec 7, 2006 | 09:49 PM
Nighteyez's Avatar
Nighteyez
Thanks for the info. ) Will check it out tomorrow.
Old Dec 7, 2006 | 10:53 PM
Nighteyez's Avatar
Nighteyez
Yepperz, curiosity got the better of me, and I went out tonight to check it. It is indeed to the right of the heater controls. Can't believe I missed it. Will try putting gas in aux tank this weekend and see if it will pull from there.
Old Dec 8, 2006 | 12:20 AM
Mil1ion's Avatar
Mil1ion
The Main tank is the rear one between the frame rails.
The Aux is tank at front ...side mounted.
Fuel tank size could be optioned.
Both my tanks hold 76 litres from bone dry to the tank nozzle.
76 divided by 4 = That's about 19 US Gallons
Old Dec 8, 2006 | 09:10 PM
Nighteyez's Avatar
Nighteyez
Cool, thanks for the info. So if I have the same size tanks as your truck, then it will cost 94 dollars to fill them both from bone dry to full. Hope I never get it bone dry )
jayro88
Oct 10, 2012 08:58 PM
abe
Sep 28, 2012 01:26 AM
cat7195
17
Jun 2, 2011 09:59 AM
junkenstien
Jul 13, 2007 12:12 PM
x2nobody
15
May 10, 2007 01:58 PM
