Tire size
Old Dec 7, 2006 | 10:37 AM
askopp's Avatar
askopp
Tire size
Just wondering if anyone knows for certain what is the widest tire that can be put on a stock 66 shortbed. Original equipment was the equivalent of 215-75 R15. I know that 235-70 R15 fits, as that is what is on the truck now. It looks like the rear wheel is limiting factor, in that it has about an inch and a half more before it hits the rear frame rail.
Anyone know for sure whether a 265-60 would fit?
Thanks,
Andrew
P.S. Banjopicker, please give me a call again. I recieved your phone message, but when I went to replay it so that I could call you back, I realized you inadvertently didn't leave your number.
Old Dec 8, 2006 | 07:02 PM
airharley's Avatar
airharley
The main issue you are going to run into is wheel back spacing. What is the distance to the bed fender lip? I have ran 275/60-15's with no problems on my truck but its a 64. You can make a wheel back spacing gauge with a wire coat hanger or better yet a carpenters square. Use it to measure how wide of a wheel will mount before the tire contacts the springs/frame and fender lip. Take off your wheel and place the square flush on the flange. The little leg of the square will measure the distances for you. Then place a flat edge across the wheel and measure to the inner wheel mounting flange.
Old Dec 11, 2006 | 03:27 PM
askopp's Avatar
askopp
Just wanted to follow up with the board on this question. This past weekend, I mounted 265/60 R-16's BF Goodrich Radial T/A's on a set of 16 inch Cragar SS on my 66 custom cab.
They fit fine, but let's just say it's very close in the rears. Like maybe 1/4" of room between the tire and the frame rail.
andrewzx92000
Feb 24, 2013 11:17 PM
CampSpringsJohn
Kentucky Chapter
Nov 27, 2012 12:50 PM
Andrew010
6.7L Power Stroke Diesel
Jan 24, 2012 02:47 PM
hallab
Mar 15, 2006 12:40 PM
agdude
Bronco II
Feb 25, 2004 02:50 PM
