Question about prolonged sitting.
Your insight would he appreciated
Toyman
Pour in double dosage, fill it up all the way, drive truck to mix it up and circulate it through your fuel system (20 - 30 minutes of driving).
Motors do not like to sit as the oil on the cylinder walls wears/drains off. I would at least drive it 1/month for 30+ minutes to get all fluids up to temp and burn off any moiosture in the oil , tranny and keep the motor lubed up.
Just to start and idle is not good and creates more mositure and problems than just sitting. I am usre you can find a reason at least 1/month to drive it for a day or two then park it again... heck their fun to drive... right!!!
Here is how I am looking at it. This truck has fairly low mileage on it already, I have something else to drive so why put the salt causing rust and winter crap on my 04 Harley truck. It seems I could put in an additive in the oil and start the truck and let it run for an hour or so every month and not have a moisture issue in the engine. I have it up on jack stands so the tires don't get a permanent flat spot in them. This also allows me to walk by and spin the tires from time to time and circulate the gear lube so there is no rust forming on the gears (I've always done that on my other truck that I've stored). I'm only talking until spring 5 months probably. I've seen trucks on dealers lot for longer than that with no problems.
Any body have suggestions for a good oil additive.
Toyman
Toyman
Just drive it and enjoy it. If you concerned about snow and salt... just wash it well before you put it back in the garage. There was an old TSB or message to dealers and ambulance outfitters )1 - 2 years ago) that frequent "short-term" starting and "driving on the lot" is not good for a new and "not-broken in" motor. These motors wantg and need to be used and driven.
You ask for a name of a fuel additive... and I gave you one in post #2 above... "Powerservice" brand in the white bottle (which is their winter/anti-gel formula).
Says it all... possible reasons for some poor running issues with certain people's trucks...
May have to cut and paste link to work as it is a pdf file link...
https://www.fleet.ford.com/truckbbas/non-html/Q125.pdf
I am willing to break in the motor on your truck during your winter months. Nobody else has offered, but I will sacrifice one of my other vehicles to continue to add mileage to your engine. Here in California we live in the sun, so we don't have any salt or major rust problems. I promise to keep in clean and your tires won't have any flat spots once I return it to you. I am saving you headache of adding fuel stabilizer, placing the battery tender, tire flat spots,animal and insects from building there residence on your truck. Once spring arrive, you should have a properly driven engine and no flat tire spots.
I guess I will take my chances by letting it sit. I'll find some oil treatment and put the fuel additive in this weekend.
I know these trucks are ment to be driven, but I have a 94 that I plow with so most of my winter is spent in that or on the snowmobile.
Thanks for all the advise.
Toyman
Toyman
Wow... didn't we answer your question on why not to let it sit.... but you will anyway.... so why did you even ask the question... or were you hoping one person would give you the answer you wanted toi hear???
Good luck... you may need it... but good luck anyway.
The reasons you gave for not letting the truck are really making me thing that I should sell my 04. I do enjoy driving the truck. Who in there right mind would not enjoy driving a super duty let alone a Harley edition #671, that thing has peoples heads turning where ever it goes.
As far as the whole situation goes the truck is already a time bomb, it sat for most of the summer while the house was being built. I've only put 4000 miles on it this year. Heck I only rode my Harley 1200 miles this year. If it is prone to breaking a rocker it could do it the next time I start it up, or should have done it in August after it sat for 3 months.
Toyman
Here's what I will do, store the truck, the same way I have others. I'll post if there is any trouble in the spring when I get it back out.
Again thanks for the info Beachbumcook, and all others.
Toyman
