Timing Light
Old Jan 22, 2002 | 10:00 AM
saxtonj's Avatar
saxtonj
Timing Light
How would one go about hooking up a standard 12V timing light to a 6V Positive Ground '49 F-1. Is this even possible? I have been told it will work, but don't wanna ruin my timing light "hacking" the correct connections.
Thanks a lot!
Old Jan 25, 2002 | 01:36 PM
50F2's Avatar
50F2
Timing Light
I have done it and it works, but the light is weak. I got better results from using a 12v battery (in my gmc van) to power the timing light, and just hooked up the other wire as usual to #1 spark plug.
It worked fine that way.
Old Jan 25, 2002 | 07:32 PM
jml's Avatar
jml
Timing Light
Do they even make 6 volt timing lights anymore? jim
http://www.48f-1.com
Old Jan 25, 2002 | 09:45 PM
50F2's Avatar
50F2
Timing Light
If they do I bet they are hard to find and pricey. Sounds like a swap meet item to me! I wonder if the bulb could be replaced with a suitable 6V unit, or if other electronics would need replacing. Like I said, I used a 12v light on my 6v truck, and it worked, but the light was faint. Its actually just easier to have a 12v batt handy and do it that way.
Old Jan 30, 2002 | 08:30 AM
selbyrk's Avatar
selbyrk
Timing Light
Old Jan 30, 2002 | 06:01 PM
rogerf100's Avatar
rogerf100
Timing Light
I found a current add for a 6/12 volt timing light using a bright xenon bulb and single wire hook up with a clamp on connector. Operates on 2 D batteries for $49.95, 1 year warranty. You can get one from Hot Rod and Custom Supply 941-574-7744.
Rogerf100
55 F100
<TDUB>
Modular V10 (6.8l)
Dec 25, 2008 10:44 AM
rwjr
Electrical Systems/Wiring
Oct 21, 2008 11:08 PM
guanabeachhouse
1997 - 2003 F150
Jul 18, 2007 03:52 PM
Richard2212
Modular V10 (6.8l)
Sep 1, 2005 07:09 PM
ktm520mxc
Aug 13, 2004 11:52 PM
