Optimum RPM
Old Dec 6, 2006 | 05:03 PM
don766's Avatar
don766
Optimum RPM
Way back in high school auto, they use to teach us to keep your RPM around 2100-2500 when driving down the road. In my truck with the overdrive on I would be running at about 85 to 90 miles an hour, (5.4 Super cab 3.73 4wd)
Are modular motors designed to run at low rpms (under 2000) or should the over drive be turned off more often.
Old Dec 6, 2006 | 05:35 PM
ohboy44's Avatar
ohboy44
Forget what you learned in auto shop and drive the truck what ever speed you want and don't worry about the RPM's.
Mine runs about 2000 RPM at 65-70.
Old Dec 6, 2006 | 07:13 PM
roush06f150's Avatar
roush06f150
The only time I lockout the overdrive is when passing on the highway.Instead of a 4-2 downshift, its a 4-3 shift which is easier on the transmission.
Old Dec 6, 2006 | 10:26 PM
don766's Avatar
don766
Wouldn't that be a 3-2 shift? With the overdrive being 4th gear?
Old Dec 7, 2006 | 07:57 PM
roush06f150
[QUOTE=don766]Wouldn't that be a 3-2 shift? With the overdrive being 4th gear?
My mistake,Your right.
Old Dec 8, 2006 | 09:03 AM
KevinM's Avatar
KevinM
These Ford engines develop 90% of their torque in the low rpm range, that's why there is such a steep overdrive. So The old 2100 to 2500 rule is old school Now a 4 cylinder low dispklacement engine maybe closer to that rule. The 3v 5.4 is almost at peak torque at 1800.
As far as down shift from 4 to 2 or 3 to 2 makes no difference on the trans at all! It still has to go thru the same procedure just skips 3 when in 4th.
The only real resaon to keep it out of 4 the is if the trans is constantly down shifting.
Old Dec 8, 2006 | 10:06 AM
Coupleofords's Avatar
Coupleofords
5.4 seems to like 1800 rpm...
just finished a 2000 mile trip towing 20 ft. enclosed trailer....halfway empty, returned loaded with car. Played with mileage alot. Locked out the O/D for reduced gear 'hunting', and actually improved mileage to avg. 13.6. Best was right at 1800. Brian
www.brianferrin.com
Old Dec 8, 2006 | 08:39 PM
roush06f150
The only real resaon to keep it out of 4 the is if the trans is constantly down shifting.[/QUOTE]
I was told its less wear and tear on your auto trans, when passing on the highway, shifting from 3-2 than a 4-2 downshift at w.o.t.
Was I misinformed??
Old Dec 8, 2006 | 10:24 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
in all reality you have to put your foot into the pedal pretty good to get a 4 to 2nd gear downshift. I'd be more concerned about torque converter wear
Old Dec 9, 2006 | 02:23 PM
()smoke()'s Avatar
()smoke()
www.brianferrin.com
13.6 sounds like really good mileage--that's a lot of wind resistance and decent amount of weight with that trailer...that's good to hear!
Old Dec 11, 2006 | 06:00 PM
04F150SC's Avatar
04F150SC
Mine runs at 2000 RPM from 68-70 mph.
794by
New Member Introductions
15
Apr 9, 2014 08:55 PM
Jeremy Kamutzki
Dec 11, 2013 08:35 PM
Artagra
Oct 10, 2012 09:49 AM
qwertmonkey
Jan 17, 2008 08:23 AM
PowerstrokeJunkie
18
Mar 19, 2007 05:03 PM
