It may give better throttle response than the 750. The 750 should be fine though, it either needs a couple of sizes smaller on the jets or the power valve is blown.
Yeah, you have to pull the front bowl off to look at the number on the jets.
A blown power valve will make it run overly rich, but it may still run ok.
If it is a LIST#3310-2 or 3310-3 then I believe that 72 jets are stock.
Yeah, that power valve should be fine with a stock camshaft.
If ti starts ok when cold, then I wouldn't adjust the choke. As it gets colder, it will close tighter. If it isn't starting good, then we can work on the adjustment.
It starts pretty good, but after say 10 seconds or so of idle, she starts to idle a bit rough. Nothing major, but it seems like the idle speed slows some.
