Blown C6
Old Dec 6, 2006 | 04:25 AM
effie351's Avatar
effie351
Blown C6
G'day Guys
I have a '79 F100 351C-C6-9'
I am looking at blowing the Cleveland. But from my limited understanding of auto's they use manifold vacuum to sense when to shift.
With a blower the manifold will be under positive pressure all the time.
So do you have to lock up the auto or is there a magic trick to enable the transmission to remain an 'auto'.
Thanks
Mike
Old Dec 6, 2006 | 03:36 PM
DOUBLEF222's Avatar
DOUBLEF222
Put A Manul Valve Body In The Tranny. It Still Would Be An Automatic But U Would Have To Shift It
Old Dec 6, 2006 | 09:43 PM
WarWagon's Avatar
WarWagon
B&M makes a little device called a "modulink" that I hae used with success. It links the modulator valve to throttle pressure. It should work in your cituation. Of course, I'm sure someone will tell you it's a piece of crap. I have had good luck.
Old Dec 6, 2006 | 09:44 PM
WarWagon's Avatar
WarWagon
By the way a manual valve body isn't a good idea on a street vehicle mainly because it does engauge the low reverse band. You will loose your low gear braking.
Old Dec 7, 2006 | 04:37 AM
stuart1's Avatar
stuart1
A C6 does not have a low reverse band.
Old Dec 7, 2006 | 06:08 AM
WarWagon's Avatar
WarWagon
Brain fart........I was thining of a C4.
Old Dec 7, 2006 | 06:14 AM
stuart1's Avatar
stuart1
haha. Been there, done that.
Kar-Knocker
26
Aug 5, 2013 07:28 PM
imlowr2
Engine Swaps
Dec 11, 2007 11:31 PM
jesse1385
Feb 13, 2005 05:10 AM
Crazy Canuck
Exhaust Systems
Mar 15, 2004 10:23 AM
84Maztang
Jun 13, 2003 04:58 PM
