New Power Elbow
Old Dec 5, 2006 | 11:08 PM
birddogs462's Avatar
birddogs462
New Power Elbow
Has Anybody tried the new Power Elbow from Accufab. If so did it work?
Old Dec 6, 2006 | 07:47 AM
Lonewolftx's Avatar
Lonewolftx
Arrow Did it . . .
Yes, can tell you it seems to be working. I have done so many mods at one time I can't give you a specific answer. My SCT Xcal tuner guy recommended it based on what he had seen on the dyno tests.
Here is the install of it in from my gallery, I got the polished one.
Old Dec 6, 2006 | 07:51 AM
satcom40's Avatar
satcom40
How does this work and what it cost
Old Dec 6, 2006 | 07:55 AM
Lonewolftx's Avatar
Lonewolftx
Talking Here u go . . .
It is a racing style intake elbow that is smoothed and ported for best intake. The website is www.accufabracing.com
http://www.accufabracing.com/diesel.htm
Old Dec 6, 2006 | 08:04 AM
satcom40's Avatar
satcom40
Thanks for the infor.
Old Dec 6, 2006 | 09:38 AM
Lonewolftx's Avatar
Lonewolftx
Talking No worries . . .
U R welcome. Hit me w/ some reputation points if you like . . .
Old Dec 6, 2006 | 11:48 AM
thedaddycat's Avatar
thedaddycat
Another thing I've seen is the TAG(Turbine Air Guide) which is supposed to straighten out air flow at the turbine inlet, changing it from a swirling pattern to a straight(laminar flow) pattern. This is claimed to allow more air into the turbo for higher density.
I looked at one site and these elbows are about $160-180 depending if you want polished or not. The TAG is about $100 for the 6.0 PSD. I'd be interested in what kind of economy increase(MPG) either of these gives, if someone who has them installed would be so kind as to report real world results.
Old Dec 6, 2006 | 01:25 PM
satcom40's Avatar
satcom40
shur, how would I do that. I give you a couple.
Old Dec 6, 2006 | 02:26 PM
mountaincat900's Avatar
mountaincat900
Good write up and dyno test on it in this months Diesel power mag.
Old Dec 6, 2006 | 04:37 PM
JORYLEE76's Avatar
JORYLEE76
This makes me so mad.. I have a subscription to DPM and every time I hear about other people talking about it long before I ever get mine... what a bunch of crap.....
Old Dec 7, 2006 | 07:34 PM
Mark _G's Avatar
Mark _G
They got 9.33 hp and 17.63 lb-ft at the peaks. It was a stock '06 F-350 6.0 dually. They said it averaged 5-10 hp and 5-15 lb-ft from just off idle to 4,000 rpm. I might just have to buy one of those as my first real power modification.
Mark
Old Dec 7, 2006 | 10:01 PM
Bear Hunter's Avatar
Bear Hunter
It's a good MOD and well worth it IMO. It also makes it real easy to put in a boost line since it is pre-drilled and tapped.
Old Dec 22, 2006 | 06:21 PM
Mark _G's Avatar
Mark _G
I got my Christmas present early and installed it Wednesday. It seems to help a little, but it is the only performance mod I've done so far. I'll see how it seems after it's been on a while.
Mark
Old Dec 22, 2006 | 07:03 PM
HeavyAssault's Avatar
HeavyAssault
I see an exhaust and tuner in your future.
PLEASE keep us posted on your results. I don't know of any other trucks running the APE without any other mods. Hey that's a cool mod name.................
Old Dec 22, 2006 | 08:26 PM
F350SD's Avatar
F350SD
I just got one. The problem is that it had the boost port at the base, right next to where the EGR is. So I called Accufab and I have to send it back to them and they will send me a replacement with the boost Port located in a better place. So I guess I am waiting a couple more weeks to find out if it is any good.
