Sponsored by: Real Truck
What size U-bolt?
Old Dec 5, 2006 | 09:05 PM
Fuxton1's Avatar
Fuxton1
What size U-bolt?
Ok so im putting a 5 inch block on top of my stock block on my srw f350. What size u bolt do i need? Thanks in advance.
Old Dec 6, 2006 | 12:10 AM
biz4two's Avatar
biz4two
Arrow
Take your current u-bolt with you to a suspension shop...and tell the guy to make you one that is 5 or 6 inches longer.
Around here...they like to make them about 2 or 3 inches longer than you need...and expect you to cut-n-fit to your needs.
Hope this helps some...
biz
Old Dec 6, 2006 | 07:30 AM
Fuxton1's Avatar
Fuxton1
I'd rather not use that much block. Can i just swap in an 8 inch leaf spring? I have a basic 6" fabtech lift with a 2 1/2" spacer in the front.
Old Dec 6, 2006 | 09:44 AM
heidiandmax's Avatar
heidiandmax
Using a spring instead of stacking blocks is a good move!As far as the 8 inch spring sounds about right.
Old Dec 6, 2006 | 03:33 PM
Fuxton1's Avatar
Fuxton1
ok so does anyone know if the 8inch spring will bolt right up? I hope so.
precisiontile
Feb 10, 2013 11:22 AM
Rcmgiasson
1997 - 2003 F150
Feb 5, 2006 02:34 PM
high ho silver
Mar 5, 2005 09:39 PM
