windsghield washer pump
Old Dec 5, 2006 | 08:04 PM
zzjonze's Avatar
zzjonze
I have a 1987 ford f150 and the windshiels washer isn't working.
So I checked fuse and wiring and im geting fire it looks like.
I called ford and they wanted $37.50 for a pump which they didnt have in stock.
So I went to salvage yard and took a tank off and brought it back and jumped 1 post to positive post and one to the negative and it didnt work directly off the battery. So After going back and trying 4 more tanks and pumps I never found one that worked.
Am I doing something wrong by checking them this way? I find it hard to believe 5 differnet pumps were bad. Somwe were off explorer which look the sam some were from f150 trucks.
ZZ
Old Dec 5, 2006 | 08:49 PM
zzjonze's Avatar
zzjonze
I gues snever mind about the washer pump. I just looked and autozone haspumps for $12.99.
SO I'll just put a new one on, and if that doesnt do it I'll get back to ya all.
ZZ
Old Dec 5, 2006 | 09:29 PM
Talyn's Avatar
Talyn
They run off a relay. It could be your relay is just bad.
Old Dec 6, 2006 | 07:01 AM
EPNCSU2006's Avatar
EPNCSU2006
You sure? Where is the relay?
Old Dec 6, 2006 | 04:49 PM
zzjonze's Avatar
zzjonze
I installed the new pump from AutoZone for $12.99 and it worked fine now.
Thanks
ZZ
