clutch fork
Old Dec 5, 2006 | 12:37 PM
tgowers's Avatar
tgowers
clutch fork
is there some sort of keeper or pin that keeps the clutch for in place on the pivot point? if there is one on mine i can't find it? thanks, tony
Old Dec 5, 2006 | 12:39 PM
tgowers's Avatar
tgowers
i forgot to tell you what it's off of...... 1968 f 100, 360, 3 on the tree, 2wd
Old Dec 5, 2006 | 11:59 PM
tgowers's Avatar
tgowers
so has anyone had their trans apart and messed with the clutch fork? there must be some kind of keeper on the clutch for where it pivots.... i need to find out what it is, how it goes on, and where i can get one.....in a jiffy! thanks again guys. -tony
Old Dec 6, 2006 | 12:13 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
There is a tab on the side of the pivot blade that a almost straight (slight bow) spring steel wire hooks on to hold the fork in the pocket it pivots on. At least on the fork of a NP435 boxed truck. You should have two small holes across the fork where the spring passes thru, ends are bent over to secure in place.
