Windshield Washer Fluid Froze
Old Dec 5, 2006 | 10:28 AM
aklim's Avatar
aklim
Angry Windshield Washer Fluid Froze
Windshield fluid froze. Is there some sort of additive to keep it going at lower temps? I heard you can add rubbing alcohol to the mix. How much to a gal of the stuff? TIA
Old Dec 5, 2006 | 11:09 AM
kbeefy's Avatar
kbeefy
Depends on how cold it is, 10-20 percent should do it. We have extra cold fuid around these parts, good to -40 instead of the normal 20 or 0.
Old Dec 5, 2006 | 11:30 AM
nodakford's Avatar
nodakford
Rubbing alcohol will work. Last year I did not get the cold weather fluid so I added about 1/4-1/2 a bottle to mine. Only thing is when you use it, it smells like rubbing alcohol.
Old Dec 5, 2006 | 12:11 PM
aklim's Avatar
aklim
I guess I can live with rubbing alcohol smell better than no fluid. Thanx for the help
Old Dec 5, 2006 | 01:19 PM
shenders99's Avatar
shenders99
Not to hijack the thread, but I got the cold stuff and am not sure about adding it. My resorvior is almost full. Can I mix it with the existing stuff? Same with the wife's van.
Thanks...
Old Dec 5, 2006 | 02:17 PM
ryaneverk2's Avatar
ryaneverk2
Scott, there shouldn't be any harm in mixing the stuff, if you don't feel like waiting until your current fluid in the resevoir is used up.
Aklim, you should look into the cold weather fluid, like the others mentioned. They actually don't even sell that stuff around here... some environmental b.s. reason, supposedly. I'm going to start picking up a bottle of it in Tahoe each year.
Old Dec 5, 2006 | 02:26 PM
Orezona's Avatar
Orezona
I like the Orang RainX with de-icer. It's pretty cheap at the Auto Parts store and doesn't freeze.
Old Dec 5, 2006 | 02:29 PM
Kwikkordead's Avatar
Kwikkordead
I'm guessing the reason you can't get it in Kalifornia (mis-spelling intentional ) is that it doesn't get THAT cold there unless you are in L. Tahoe or something.
Old Dec 5, 2006 | 04:25 PM
monsterbaby's Avatar
monsterbaby
the main difference between normal and winter washer fluid is the amount of methanol that is in it. As I recall summer or normal washer fluid is something like 10 or 20% winter stuff is mixed 50% methanol
Old Dec 5, 2006 | 09:05 PM
Smokin''s Avatar
Smokin'
Smokin
I didnt even know they sold washer fluid that froze.
The de-icer stuff is pretty cool it helps on those mornings when you have just a few flakes of frost on your windshield, the type that doesn't deserve scraping.
By the way you can buy washer fluid online.
Washer Fluid
Old Dec 5, 2006 | 09:48 PM
aklim's Avatar
aklim
Was about to dump some isopropyl alcohol in it when I noticed the frozen mess in the reservoir. Dumped the whole bottle of iso and it seemed to melt stuff. Found some -20 fluid and dumped it in. Lets see how it performs tomorrow.
Old Dec 6, 2006 | 12:42 AM
Stewart_H's Avatar
Stewart_H
That's what I always thought the reason was. I always figured they only sold the cold climate stuff in the colder climates.
Andrew, where the heck are you located bro?
Stewart
Old Dec 6, 2006 | 01:16 AM
ryaneverk2's Avatar
ryaneverk2
Yeah that's what it seems, but if folks will buy it, why not sell it everywhere? I think that's where the chemical/environment part comes in. Maybe if it's not necessary around here, then they won't allow it. Who knows...
Accordin' to Andrew (aklim's) info, he's in Madison, WI. Brrrr, cold!!!
