1957-60 gauges
Old Dec 5, 2001 | 12:50 PM
58f100's Avatar
58f100
1957-60 gauges
well kenny,
all of my dashes are silver over black with faded dayglow orange needles, i have a mech tach i picked up< any ideas how i can use it ,working, in my 58 272 f100, what type of tach drive on dist , dist can i use?
garry 58f100
Old Dec 10, 2001 | 04:01 PM
atomlin's Avatar
atomlin
1957-60 gauges
kenny i have a "60" f250 4x4. the original gages ( fuel,spedo,temp ) are gray type of silver. I am a new user. i don`t have much info on this old horse tho i have owned it for about 35yrs. grumpaw
Old Dec 18, 2001 | 06:23 AM
wosborn's Avatar
wosborn
1957-60 gauges
My '59 panel standard cab has silver guages. I'll check my '60 panel custom cab later.
Old Jan 23, 2002 | 07:39 PM
howefiretr's Avatar
howefiretr
1957-60 gauges
my 59 f-100 has silver faces - but my 60 parts truck had the copper face hope this helps
Old Jan 24, 2002 | 08:33 PM
19F10059's Avatar
19F10059
1957-60 gauges
KENNY just looked in my 59 and my 58 all gauges in mine are silver-gray with the glow paint both are regular cab not custom cab
Old Jan 25, 2002 | 08:10 AM
Kenny's Avatar
Kenny
1957-60 gauges
Thank you for all the replies!
Wow, so far only one other guy with copper faced gauges? Hmmm, there doesn't seem to be a real pattern here. I remember seeing tons of '59 custom cabs that had the copper faced gauges when these trucks still weren't that old. This is wierd.
Old Feb 10, 2002 | 12:42 AM
whd507's Avatar
whd507
1957-60 gauges
Old Feb 11, 2002 | 06:42 PM
darkman's Avatar
darkman
1957-60 gauges
Hey Kenny,
Did you ever get any pics of the copper face gauges or tach dash?
Charles in Pensacola
Old Feb 11, 2002 | 08:29 PM
bhabben's Avatar
bhabben
1957-60 gauges
Charles,
Saturday I stopped to look at some spent oil rig trucks, ranging from 53 on up. There was a 59 with the tach mounted on the left side. It only went up to like 3000 rpms. or so, and about the same diameter as the speedometer. The cluster is obviously designed for this. The interesting thing is that this same tach was in some of the other trucks, earlier and later.
After seeing this is would be awful tempting to mount an aftermarket tach in the factory location.
Adios,
Brett
Old Feb 11, 2002 | 09:05 PM
Kenny's Avatar
Kenny
1957-60 gauges
Hi Charles,
Finally got around to snapping a picture. It may be hard to see, but the speedometer is tarnished copper, and on the other gauges the plating came off when I tried to polish. Sorry it took me so long.
https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=1637&.jpg
Old Feb 12, 2002 | 12:03 AM
moneypit57's Avatar
moneypit57
1957-60 gauges
Kenny, my '57 custom cab has the silver guages.
Old Feb 12, 2002 | 07:01 AM
darkman's Avatar
darkman
1957-60 gauges
Brett,
You are right on target. I was thinking of replacing the tach if it was broke or too low RPM. Did they also have the vacuum gauge. Now I just need to find one.
Kenny,
Did they all have a 3000 RPM limit. Picture looks good.
Thanks
Old Feb 12, 2002 | 06:59 PM
  #28
bhabben's Avatar
bhabben
1957-60 gauges
Charles,
None of these trucks had vacuum gauges. The same 3000 rpm tach was in a range of years. These were severely used hulks, so it is hard to say what was original in them.
Adios,
Brett
Old Feb 13, 2002 | 04:58 PM
  #29
brewster1's Avatar
brewster1
Post 1957-60 gauges
I am the second owner of my 60 with custom cab. The gauges are grey
and the speedo is grey with silver center. They are definitely the
original gauges. I have owned the truck since 1970.
BTW old Econoline (circa 61) has same instrument cluster as the 60 in case anyone is interested.
jt
Old Feb 14, 2002 | 07:54 AM
  #30
Kenny's Avatar
Kenny
1957-60 gauges
Hi Charles,
The bigger trucks had the tach and vacuum gauges. Also, the tilt cab had the same instruments and bezel as the F-series. I see them on e-bay from time to time. I hope this helps.
Everyone,
So far from all the data here, there seems to be no ryme or reason so far as to which year/model had the copper faced gauges. I really do appreciate all the replies. You guys are the best! Thanks.
