Sponsored by: Real Truck
ck oil pressure light
Old Dec 4, 2006 | 08:16 PM
joeycyph56's Avatar
joeycyph56
I have an 04 5.4l that when i start it the oil light will light for a sec and also the mini message center will flash ck oil pressure. than they both turn off and the pressure is where it always is .Is this just a delayed sensor reading?.. It seems that i notice it mostly when it gets cold out.i Just run motocraft oil that i get changed every 3000 or 3 months by the dealer. any thoughts or am i just being a little too concerned over nothing.
Old Dec 4, 2006 | 08:21 PM
PHWLEE's Avatar
PHWLEE
Sounds like the oil is thicker because of the cold and it's taking a little extra time to get moving. Are you in a cold part of the country? The manual for the V10 says it takes a 5W-20 Synthetic Blend. Not sure about the V8 so maybe someone else can chime in and help.
Old Dec 9, 2006 | 03:14 PM
spud57's Avatar
spud57
I had the same problem on my V10. Replaced the oil pressure sending unit for $15 and half hours labor. Problem solved.
