How Much HP
Old Dec 4, 2006 | 01:09 PM
The Freak's Avatar
The Freak
How Much HP
I just recently got my new truck pulling engine running. It sounds strong. I was wondering what you guys think it should be pushing for HP/Torque. Here is a list of the details:
429 Dove block bored to 4.440
Block milled to 10.250
Hard blocked
Bronze bushings installed in lifter bores
Roller cam bearings
4.020 Stroke Crank
Eagle 6.7" Rods
JE Pistons-13:1 Compression Double Cut Valve Reliefs for SCJ and TrickFlow
Comp Solid Lifter Roller Cam 761 Lift 280 Duration
SCJ Cast Iron Heads-Ferrea Valves
Slight Porting on exhaust side of heads
Copper Head Gaskets .041
Roller Rockers-1.73
Custom Upright Truck Pulling Headers 21/4" x 4"
Everything Studded and Girdled
Mallory Distributor-MSD 6AL
Electric Water/Fuel Pump
Offenhauser SCJ Tunnel Ram-Single Four Barrel Top Plate
1090 King Demon
Old Mar 18, 2007 | 05:45 AM
booneyrat75's Avatar
booneyrat75
If my math is right, you have a 498cid stroker. Your best bet is to find someone with the "desktop dyno" program. The only way I've ever seen to get an accurate horsepower rating is to go by your truck's weight and ET. Whatever you find out, I'd bet is some pretty serious horsepower. Nice build, Brutha!
Old Mar 18, 2007 | 07:46 AM
79superduty's Avatar
79superduty
Post
i ran it through mine, and dont have any head flo#s, but its a pretty good set up i ran the tunnel ram with a single 1200 dom. and a desecent set of heads and your up in the 630 hp at 5500 rpm , and great tourqe at 4200 to 5200a strong 650 footlbs
Old Mar 19, 2007 | 08:34 AM
The Freak's Avatar
The Freak
As far as cubic inch, that is pretty close to where I thought I was. The cu. in. limit for my class is 496, but they allow 2% if pumped. That is pretty close to where I thought the horsepower would be. The torque numbers seem pretty good and that will definately help when it comes to pulling. I've been trying to get it around the 700 hp range, but I'm restricted to running cast iron or factory production aluminum heads. I spent a decent amount of money to get it where it is at now. I want to run it this season and see how everything goes and then next year spend some more money and try to get a little more out of it. I know head work always helps. Just to pick your guy's brains, what would you guys add or do different??
Also, I saw Trick Flow now has an intake that will fit on the factory production heads. Has anyone used this intake?? If so, what did you think??
Old Mar 20, 2007 | 07:10 AM
79superduty
you dont have to go with the TFS, a victor is just as good. i think your set up is good. i basically have the same set up just a little more cubes.i would leave it alone untill it breaks. you can get a little more by throwin another carb or a bigger one but see how it works this year..
