Turbo Timer
Old Dec 4, 2006 | 11:51 AM
Flywest's Avatar
Flywest
Turbo Timer
Turbo Timer?
Had turbo diesels for many years now, this is the first with a turbo timer on it!
When I turn the key off and get out, theres a aftermarket turbo timer with green led's that shows various lengths of time and keeps the truck running for that period of time before shutting the engine off!
I have no idea how it knows how long to idle down the engine - it seems to make up it's own mind and do it for varying lengths of time depending on how far / fast I've been driving!! (How hot the enegine is?)
I notice that when I turn off the key, but the engines still running on turbo timer, the power windows cease to work, as do the power door locks (central locking)...
You basically have to stand there, like a stale bottle of beer in the sun, or a sunstruck seagull, waiting for however long it takes, for the engine to idle down and shut off, before you can lock the car doors and walk away!
Is this normal?
I also notice...after it shuts down - if I walk past the exhaust, I can hear the turbo fan spinning down and blowing air out the exhaust... I presume this is a good sign?
Does everything sound "normal"?
Thanks in advance!
Cheers!
Old Dec 4, 2006 | 01:05 PM
Uzumati's Avatar
Uzumati
You will hear the turbine winding down after shutdown. Some of the timers have temp probes to determine when to shut down some just have set times. Look under the dash to see if you can find a "Control" box for the timer a brand might yeild more specific results. Not sure on the window and door issue I think I remember reading on one brand that did disable everthing while the timer was in controll.
Old Dec 4, 2006 | 01:34 PM
hookd's Avatar
hookd
open the door and hit the locks before you shut it off?
Old Dec 4, 2006 | 02:53 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
Find the unit and put a toggle switch on the power wire, that way it gives you the flexability to use it when you need it.
Old Dec 4, 2006 | 04:12 PM
pullinair's Avatar
pullinair
My buddy had one on his 7.3L, If my memory serves me right, he could take his key out of the ign. (it would stay running),shut his doors and hit the remote lock button as he was walking away and it would shut down on its own after the timer got to a safe temp.
I wouldn't get frustrated with yours and just take it out. Just make sure it is wired correctly. Refer to the manufacturer for assembly instr. It is an excellent device to have in your truck.
