Heater Core Leaking
Old Dec 4, 2006 | 08:54 AM
Kazco's Avatar
Kazco
Heater Core Leaking
Just noticed antifreeze dripping on the floor. Had a smell for a few days and now water dripping.
How hard is it to remove the heater core? Any tips from those who did it before. Is it worth repairing (short down time) or should I just buy a new one (and wait on getting one shipped). I plan on adding classic air down the road (maybe spring).
Thanks,
Mike
Old Dec 4, 2006 | 09:35 AM
Fritolay's Avatar
Fritolay
the heater on these old trucks is very easy to work on most parts stores should be able to have you one in a day or so and the one i just looked up at oreilys is 17 bucks.
Old Dec 4, 2006 | 09:47 AM
merlynr's Avatar
merlynr
Smile
ditto what Fritolay said. Just put new one in 71F350. My biggest trble was reconnecting the rubber bellows looking part that connects the fresh air vent to the heater box. I think I should've tried connecting it before I had the heater bolted back up to the firewall. Good time to get debris out of heater too.
Old Dec 4, 2006 | 10:04 AM
jowilker's Avatar
jowilker
Mike They are available at any of your favorite parts houses, and I think all the way to 79 are the same. You should be able to find them stocked.
John
Old Dec 4, 2006 | 01:18 PM
Kazco's Avatar
Kazco
Thanks to all. It was dark this morning when I saw the water dripping. It sounds like it should be a fairly easy fix.
I looked on the web and autozone has one from $17.00. Takes about a day or two for delivery.
Thanks,
Mike
Old Dec 4, 2006 | 04:22 PM
jowilker's Avatar
jowilker
Mike, Online is not the store. You should be able to go to the store, pick one up and fix it today.
If you want to that is.
John
Old Dec 4, 2006 | 07:28 PM
my72ford's Avatar
my72ford
i bought mine at advance auto a couple years ago for about $20 and has a lifetime warranty,i had the old one out and new one in in about 45 mins..very easy! prob one of the easiest i have done
Old Dec 5, 2006 | 07:23 AM
Kazco's Avatar
Kazco
Thanks, Autozone has one and I'm going to pick it up at lunch time..
I looked last night and am not sure where to start. Do I remove the blower motor and start from there? Do I have to remove the housing on the kick panel first?
Any guidance would be appreciated.
Thanks,
Mike
Old Dec 5, 2006 | 07:57 AM
Dave Severson's Avatar
Dave Severson
Disconnect and drain the heater hoses, then remove the 3 bolts on the firewall that hold the heater box in place..... Unless your truck has factory A/C, then the process is a bit more involved. Might try the public library for a Chilton's manual that shows the R&R procedure for the heater core....
Old Dec 7, 2006 | 07:02 AM
Kazco's Avatar
Kazco
Thanks to all for the help and thanks Dave, you were right- 3 bolts held the whole assembly.
For those who might have to do it in the future, unbolt the fresh air duct from the kickpanel. It makes it easier.
Disconnected 2 defrost ducts and its out. The heater core is under a panel that is held in with about 8 5/16's screws.
Once again, Thanks all
Mike
Old Dec 7, 2006 | 08:21 AM
Dave Severson
You're welcome. Good to see that my poor old memory still has a functional day once in awhile!!!!!!!
Old Dec 12, 2006 | 08:09 PM
baitmaster's Avatar
baitmaster
my '72 4 wheeler had a leaker some time back, two choices, one for air and one for no air. The only difference I could see between the two was that the heater hose nipples were different length. I used the one with the longer ones. (More to slide hose on). Nobody around here will fix one, just buy the new core. Cheaper.
Old Dec 13, 2006 | 05:39 PM
qman's Avatar
qman
It'd be kind of tough to fix a heater core that's rotted through.
Old Dec 14, 2006 | 08:56 AM
Dave Severson
Never bothered trying to fix one, got a brand new one at NAPA for about $20.00...
