Dana 44
Old Dec 4, 2006 | 08:32 AM
illinois4by's Avatar
illinois4by
Dana 44
Hiya boys. Anyway i have a 90 f150 and in the storm we had here in illinois i blew up my passenger side drive axle. i did find a complete assembly for 65 bucks. I thought that was a deal. Question is ive never changed them before you guys have any helpful hints so i dont screw anything up. thanks
Old Dec 4, 2006 | 09:21 AM
Kemicalburns's Avatar
Kemicalburns
get a haynes manual, will give you step by step instructions.
Old Dec 4, 2006 | 12:23 PM
andym's Avatar
andym
If you're talking about replacing the axle shaft itself, are you talking about the inner or the outer section? They are joined by a slip shaft in the TTB arm about a foot outside the differential.
Old Dec 4, 2006 | 12:45 PM
illinois4by
Yes on the passenger side both shafts need replaced. The yokes blew up with the u-joint. So im replacing the inner and outer shaft
Old Dec 4, 2006 | 12:49 PM
andym's Avatar
andym
You'll have to take off the rotor and spindle to get the axle shaft out. You'll have to remove the metal clip holding the boot over the slip joint too.
It's actually pretty easy. The hardest part is getting the spindle off. I would suggest renting a slide hammer and a spindle puller, that's the easiest way to get it off.
Old Dec 4, 2006 | 01:56 PM
MustangGT221's Avatar
MustangGT221
That is the easiest way to get the spindle off, but another way I've found that works ok is with a metal chisel and decide size hammer.
If you look on the backside of the knuckle you may find a hole that you can put a punch through and hit the spindle. I did, and got one side started by hitting the spindle from the backside. The other side of my truck didn't have the hole so I had to go without.
I basically use the chisel around the parameter and try to separate the spindle from the knuckle. It takes a couple minutes of wacking w/o progress before you finally see it separate and once it starts to separate you're home free.
You'll also need a spindle nut socket to remove the spindle nut.
I've done it 3-4 times and it's not that bad.
Old Dec 7, 2006 | 08:20 PM
illinois4by
Just wanted to let you guys know the chisel thing worked great the thing came right off the whole thing took two hours. So anyway thanks for the advice it worked great.
