Making the TC lock up box.
Old Dec 3, 2006 | 09:58 PM
John311t's Avatar
John311t
I think im going to make the TC lock up box. Is there anything i need to know before running it. I do not want to blow anything up doing it. I know you can't lock it up in first and you need to unlock it before stopping. but is there anything else i should be aware of?
Old Dec 4, 2006 | 07:07 AM
Casey's Avatar
Casey
Don't lock below 1300 RPM. The pump may not be making enough pressure below 1300 RPM to keep the TC locked. If there isn't enough pressure the clutch will slip, and then fail.
