1990 Ranger surging problem
Old Dec 3, 2006 | 02:11 PM
scootour37's Avatar
scootour37
I have a 2.3 liter and it has a problem with surging. I had it scanned and the codes said it was the egr valve and mass air sensor. I replaced the egr valve and that did not fix the problem. The air sensoris an expensive part and before I spent money on it I was wondering if anybody else out their has had this problem before. Any help would be greatly appreciated. Thanks
Old Dec 3, 2006 | 02:27 PM
john112deere's Avatar
john112deere
You can clean the MAF sensor. I believe there are instructions in the tech. sticky at the top of the Ranger forum. Make sure to do it when the truck is cold, and disconnect the battery to reset the computer.
Old Dec 3, 2006 | 04:54 PM
RangerPilot's Avatar
RangerPilot
Welcome to FTE!
What do you define as surging? The idle just fluctuating? Does it do it all the time?
If it's just a fluctuating idle, look on the side of the throttle body for a small metallic cylinder. This is the "Idle Air Control" valve, or IAC. Unplug it while the idle is fluctuating, if it stops and the idle stabilizes (it may stabilize very low and die if the engine is cold), remove the metallic cylinder and clean it with throttle body cleaner or replace it.
Cleaning the MAF is easy, though it's held on with security Torx bolts. Once you get it off, it's just a matter of cleaning it with throttle body cleaner or electrical cleaner VERY carefully, then replacing it.
Old Dec 8, 2006 | 12:30 PM
scootour37's Avatar
scootour37
Thanks for your help, I will give it a try......
02GrayPowerStroke
1997 - 2003 F150
Sep 11, 2016 08:17 PM
boduey
1997 - 2003 F150
Mar 22, 2016 07:41 PM
Peavey1986
Feb 25, 2016 07:57 AM
Dsl_Burner
Aug 6, 2012 08:57 PM
