torque converter lockup
Old Dec 3, 2006 | 12:18 PM
V10 Mike's Avatar
V10 Mike
I own 2001 f-350 V10 4x4. The torque converter is not locking up.The check engine light is on and the od light is flashing. Two codes from the computer are P1744 and P0743. Is there a switch or sensor for torque converter? If so where is it located?
Thanks Mike
Old Dec 3, 2006 | 05:52 PM
projectSHO89's Avatar
projectSHO89
Electrical problem with the TCC solenoid.
Check the solenoid's coil for proper resistance. Check the bulkhead plug and internal wiring harness to the solenoid.
If the solenoid itself shows an open circuit, replace it.
Steve
Old Dec 4, 2006 | 12:01 AM
Blurry94's Avatar
Blurry94
This may sound odd, but have you tried cycling your hazard light switch a few times?
Old Mar 3, 2007 | 11:34 AM
joedaplummer's Avatar
joedaplummer
why
what would cycling the hazzard lights do? you got me curious
Ericmb79
Dec 9, 2016 11:08 AM
BGLeRoy
Modular V10 (6.8l)
May 1, 2015 10:37 AM
kenneBF250V10
Apr 16, 2008 09:29 AM
green250
Modular V8 (4.6L, 5.4L)
Jan 27, 2007 10:05 AM
etcetera
Modular V10 (6.8l)
May 9, 2006 06:56 PM
