Sponsored by: Real Truck
PLEASE help my tranny problem.
Old Dec 3, 2006 | 09:25 AM
capn kirk's Avatar
capn kirk
I need some help does anyone know what is goin on with the tranny in my 1996 f-250 with the 460, the problem is whenever it upshifts (to go into an overdrive gear and even just a regular shift) the truck jerks forward sometimes just a little sometimes enought to pull my foot off the gas. downshifts are fine but the ups are bad. i just got a new filter and new fluid in the transmission and everything behind the pan (its a deep pan) looked real good. Thankyou for any help you guys helped a bunch with my last question.
Old Dec 3, 2006 | 11:35 AM
ReAX's Avatar
ReAX
Sounds about right, esp if you have a shift kit or modified valve body. If it bothers you, back off the accelerator just before it shifts. With a little practice, you should be able to get it to baby into gear.
Old Dec 3, 2006 | 02:56 PM
capn kirk's Avatar
capn kirk
thanks i might be being pranoid i noticed the problem when my fluid was low and i couldn't tell if it was back to normal or still off, it just feels like a little worse than normal. any ideas or should i just let it go
Old Dec 3, 2006 | 06:39 PM
ReAX's Avatar
ReAX
It's probably just the new fuild acting the way it should. If your worried, you can always let aamco take a look at it.
