generator to alternator
Old Feb 28, 2002 | 07:11 PM
jozs56ford's Avatar
jozs56ford
Post generator to alternator
does anyone know where i could find a wiring diagram on converting from a generator and regulator to an alternator on my 56. or any information about making the switch. thanks for any help
-Josh
Old Feb 28, 2002 | 11:08 PM
Franklin2's Avatar
Franklin2
https://www.ford-trucks.com/dcforum/User_files/3ada21e51c40261d.jpg
Old Mar 1, 2002 | 02:59 PM
darkhorse54's Avatar
darkhorse54
I changed my 54 f100 to an alt. years ago, get a voltage regulator from a 68 or 69 Dodge it has 1 wire going in and 1 wire coming out, put your ignition wire on 1 side of the regulator and hook the other side to the field on your alt. and besure to have your thick red wire going to the batt. on the alt. that's it mine worked perfect for years.
Old Mar 2, 2002 | 10:25 AM
brewster1's Avatar
brewster1
I changed my 60 f100 w/292 to an alternator recently using Ford
alternator and regulator. Just get the alternator,regulator,
and wiring harness all from any Ford vehicle from 65 up and it
will work. I used a Ford electronic regulator with a 60 amp alternator
and the generator light is functional. If you use an older regulator
you may have to lay a resistor across the wires that go to the gen
light (15 ohm, 10w). These can be bought at Radio Shack or a tv repair shop and are inexpensive. (If you have an ammeter, this is not necessary.) This would be done under the dash on the wires coming out of the gen light socket. This is a very simple installation and you can keep it all Ford. Ford alternators are plentiful in wrecking yards. On a y-block will need to fabricate mount for the alternator.
The wire coming from your dash indicator will probably be yellow or yellow with a black stripe and should be hooked to the "I" terminal
on the regulator. This wire originally went to the armature terminal
on your generator voltage regulator.
jt
Old Mar 2, 2002 | 10:49 PM
jozs56ford's Avatar
jozs56ford
[updated:LAST EDITED ON 02-Mar-02 AT 11:49 PM (EST)]Thanks for the info guys, i'll keep in touch if i run into any trouble with it.
-Josh
Old Mar 3, 2002 | 09:26 PM
wosborn's Avatar
wosborn
I converted the generator on my 352 to a regular Ford alternator and bought a one-wire regulator (bolts on the back of the alternator) from one of the classic shops.
Old Mar 4, 2002 | 10:45 PM
truckzilla's Avatar
truckzilla
I found a C%$#y alternator at Napa that is a true one wire and is supposed to be used in industrial applications. I put one in my 60 and liked it so much I bought another one for my 38. Hook a wire from the alternaor to the battery and BAM you're done!!.
Old Mar 5, 2002 | 12:08 AM
cabby daddy's Avatar
cabby daddy
>you're done!!.
So what is the part number????? how many amps???
robert
Old Mar 6, 2002 | 06:03 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
Old Mar 7, 2002 | 09:59 AM
truckzilla's Avatar
truckzilla
Its a Delco 10SI Series alternator. Napa Part Number 13-4011SW. It's rated at 63 amps which is plenty for what I'm running.
Old Mar 7, 2002 | 02:46 PM
cabby daddy
hey thanks truckzilla... I have the BEST napa parts guys in the state, (you can not beleive what they have located for me) and they weren't sure of which altenator i was talking about...
Robert
Old Mar 8, 2002 | 10:33 AM
truckzilla's Avatar
truckzilla
My pleasure. That's the good thing about Napa. You pay for it but they at least can help us with our dinasaurs
asmith6
Mar 5, 2016 05:34 AM
Combatwombat
Apr 19, 2015 12:20 PM
Shadowrider123
Oct 17, 2014 11:34 PM
packrat56
15
Sep 28, 2014 10:16 PM
packrat56
Sep 22, 2014 01:03 AM
