Offroad & 4x4
dana 44 carrier ?
Old Dec 2, 2006 | 06:31 PM
84FB351's Avatar
84FB351
dana 44 carrier ?
what is the differnce in cases as far as series 3 series 4 ect...? i was wondering whytheres only a certain range of gears for each series are the gears differnt sizes or cases stronger . just curious im trying to find a decent deal on a posi/locker with 4.10 or 4.56(now i have 3.50 open so do i need a new case to go to 4.10?
Old Dec 2, 2006 | 06:45 PM
bronco521's Avatar
bronco521
as far as i know there is a difference in the ring gear thickness between the 3 series and 4 series gears.i run a traction lock in the front of my bronco.you should be able to find one for under $200
Old Dec 3, 2006 | 09:49 PM
84FB351's Avatar
84FB351
so are you able to run 4.10 gears on a carrier that has 3.50 gear on it now?
Old Dec 3, 2006 | 10:24 PM
bronco521's Avatar
bronco521
no.you will need a 4 series carrier.the gears will actually be a 4.09 for a d44
Old Dec 4, 2006 | 01:11 PM
84FB351's Avatar
84FB351
i bought 4.30 gears front and rear the fronts are thick cut stock dana gears made for the 3 series case so i hope they work...
Old Dec 4, 2006 | 02:38 PM
bronco521's Avatar
bronco521
sounds good.
Old Dec 5, 2006 | 01:26 PM
84FB351's Avatar
84FB351
are the knuckles interchangeable fron the ttb to the solid axle? also do you think i can use the steering setup i have now instead of the tie rod tube and the drag link?
Y2K1TON
1978 - 1996 Big Bronco
Feb 14, 2015 09:39 AM
kountzecobra
Oct 30, 2014 03:07 PM
oldblue89
Aug 13, 2014 07:12 AM
Mr. 64
Apr 2, 2014 04:42 AM
fordtorque
May 10, 2011 07:48 PM
